Cheap ultrasonic cleaner doesn’t work anymore
  • caphair
    • Nov 2011
    • 1249
    Powers on shows a display and lets you set a duration. When I press Start I can hear a relay click and the timer counts down but it never really starts. Not sure if it's fixable or worth it but figured I'd post. Maybe someone has experience with these.
  • R_J
    • Jun 2012
    • 9632
    Re: Cheap ultrasonic cleaner doesn't work anymore
    Pull the board and look at the other side, there is likely an outout transistor that could be bad, or mybe just a poor connection.
    • caphair
      • Nov 2011
      • 1249
      I'll do that when I have a chance tomorrow. At the two terminals going to the bowl? I measure briefly around 115vac before it drops. In dc I measure around 35vdc. If that's a clue to anything. Do these work off ac at the output?
      • R_J
        • Jun 2012
        • 9632
        The output should be high frequency ac (42khz). Also Have a look at the piezo transducer (mounted to bowl) and see if it is cracked or broken
        It is a switching power supply, U1 likely drives the two fets that drive the transformer, and the secondary of the transformer drives the piezo
        • caphair
          • Nov 2011
          • 1249
          I don't see any visible cracks on the piezo transducer. Also the two mosfets seem to measure good in circuit, diode readings in one direction.
          • R_J
            • Jun 2012
            • 9632
            Check the voltage across C10, it should be at least 150vdc), then use C10 - as ground and check the voltage on the 10k/2w resistor lead (next to C12). If you have voltage on C10 and not the resistor next to C12, check the solder connections on the relay, or the relay contacts could be bad.
            Do you have VCC on the ic? or across C14?
            • caphair
              • Nov 2011
              • 1249
              By ic you mean U1? Also I'm not seeing C14 anywhere do you mean c15?
              • R_J
                • Jun 2012
                • 9632
                C15 is the small disc cap, next to it is C14 (partly covered by the screw) U1 is the only ic,
                • caphair
                  • Nov 2011
                  • 1249
                  C10 = 316vdc when “start” pressed and 328vdc when in standby
                  Same readings on R3 next to c12
                  C14 and Vcc of u1 = 13vdc when “start” pressed
                  • R_J
                    • Jun 2012
                    • 9632
                    That all seems correct, you have 316v for the the fets, and 13vdc VCC for the ic, You could check the voltage between U1 pin 4 (common) and 5 (VS) should be quite high around 150vdc. If its 0 or 316v the ic could be bad.
                    Then I would check that the transformer is not open. I took a guess as to how it should be configured.(see picture)
                    The actual output circuit is very simple, U1 has High and low outputs to drive the two fets at 42khz, the two fets switch the 316vdc to output a 42khz signal to the piezo. The transformer provides a small sample of that signal to the CT pin of the U1 If that signal is missing the IC wil shut down.
                    If you have the ic's datasheet, you will see 4 internal fets, you should be able to check that they are not shorted D~S
                    IE: from pin 7 to pin 6 and pin 7 to pin 8 should be open.
                    • caphair
                      • Nov 2011
                      • 1249
                      Found Datasheet and pins 6 and 7 measure .043 in diode mode both ways and slowly increase, but sometimes they measure .565v one way and OL the other.
                      Vs pin 6 measures 28v
                      • R_J
                        • Jun 2012
                        • 9632
                        Did you check the transformer?
                        • caphair
                          • Nov 2011
                          • 1249
                          No I actually forgot to because I thought the 28v on Vs meant the ic itself was bad. I’ll check it tomorrow. Do I just measure ohms across the three windings you drew up?
                          • CRT Informatica
                            • Mar 2020
                            • brasil
                            ola
                            • caphair
                              • Nov 2011
                              • 1249
                              Here are the values I get on the transformer. Shown in the picture I've attached
                              • R_J
                                • Jun 2012
                                • 9632
                                It looks like the transformer is just there to provide feedback to the ic. If you have a scope (and isolation xfmr) to check the ic outputs, the circuit is very simple so if the fets are ok, the transformer seems ok, you have the voltages, HV for the output fets and VCC for the ic, maybe check that C16 (across the output to the piezo) is not shorted, it does'nt leave much.
                                I would try a new ic
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  It looks like the transformer is just there to provide feedback to the ic. If you have a scope (and isolation xfmr) to check the ic outputs, the circuit is very simple so if the fets are ok, the transformer seems ok, you have the voltages, HV for the output fets and VCC for the ic, I would try a new ic
                                  The transformer isn’t stepping up the voltages at all? I don’t have a scope unfortunately. Should I just try another ic? This one is labeled IR2153 and I found replacements but it’s labeled IR2153S. Think it’ll be a suitable replacement?
                                    • 31301
                                    the large transformer has fractured solder joints.
                                    • R_J
                                      • Jun 2012
                                      • 9632
                                      The transformer is not to step up the voltage but just to provide a stepped DOWN sample voltage to control the ic.
                                      The IR2153S is just an improved version of the ic
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Alright I guess I’ll just try another ic. Cheap enough
                                        • silberdrache
                                          Burnt Hole under IC on MacBook Pro M1 Pro 14"
                                          by silberdrache
                                          I'm new to this Forum, so I hope it's the right place for this topic.
                                          Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
                                          I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
                                          The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
                                          I opened it up and there were only three drops of coffee...
                                          11-10-2025, 11:19 AM
                                        • Henke
                                          Electrolux EUO9GREEN Vacuum Cleaner doesn't start
                                          by Henke
                                          I have a vacuum cleaner that won't start. I have desoldered 2 capacitors with low value. But i don't know if they can cause that kind of problem. Someone here with any thoughts and inputs?
                                          I marked the capacitors on the pcb picture with red and blue dots. The big one marked with 334 K measures 216 nF and the other one marked 224 K measures 109 nF.
                                          01-08-2024, 11:37 AM
                                        • itsthatidiotagain
                                          CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
                                          by itsthatidiotagain
                                          CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
                                          There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
                                          I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
                                          A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
                                          06-23-2025, 03:22 AM
                                        • Stevedb
                                          Google drive missing back-ups and doesn't make back-ups anymore after reset phone
                                          by Stevedb
                                          Hi all
                                          I have anoying problem after resetting my blackview bv9900 phone doesn't find google drive my phone back&ups anyymore also doesn't make new back-ups from my phone anamore. Does anyone know why it happens and how i can fix it . I will not like to lose my data again. Also back-up button is grey out see picture.
                                          Regards Steve...
                                          07-22-2022, 03:37 AM
                                        • tricky74
                                          Chinese no brand ultrasonic cleaner
                                          by tricky74
                                          I bought an ultrasonic cleaner from ebay and after a couple of years it blew one of the driver boards fuse and a couple of diodes. I replaced the parts and it worked for a while then died again. Since then I have thrown out the board and just use one. The unit had 2 drivers and the good one drives 1 transducer only. The fried board was driving 2 transducers. The unit works on 1 transducer but is weak in power. I am tempted to connect the 2 transducers that were driven by the dead board. And leave the single disconnected. Not sure if it there is a fault in them and will just kill the driver. As...
                                          07-01-2022, 06:20 PM
