PS3 , Part replacement Issue , found the problem
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Hello everyone . For the past few days i've been trying to fix this ps3 that i got... First i thought it was the tantulum caps causing red blinking light but it didnt do anything... Then i realised that 1 chip was getting really hot really fast... and it was this chip "mm1593dfbeg" thats the part number from the schematic (motherboard is sem 001). So its a 3.3v regulator and its not outputing it... I figured that if i replace this chip the sony would be up and running ... Unfortunately i cannot find any local supplies of this particular chip ... i was wondering can i replace this chip with something more readily available ... I can put up a picture of schematic with this regulator and how its connected , so if anyone could help me engineer something that would resemble this chip that would be great... Otherwise i will need to start making some phonecalls to local shops which i doubt they will help me...
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Re: PS3 , Part replacement Issue , found the problem
    Have you checked aliexpress?
    If you can't find one or a substitute, I have few scrap ps3 boards and can mail you one of those ICs.
    • sigmeyer
      • Feb 2020
      • 158
      • Serbia
      You sending me the chip would be great but i was thinking about getting something local that i could replace it with, waiting for weeks to arrive is painful ...Thinking about replacing it with this LM2936MM ... It doesnt have the noise reduction pins ... other than that is almost identical.. If anyone has any knowledge about this it would be helpful...I dont know much about noise in electronics or how it would affect the whole system...
      • sigmeyer
        • Feb 2020
        • 158
        • Serbia
        I just noticed that on original chip there is also a control pin :S ... so this just got alot more complicated... Cannot find anything on aliexpress or ebay... really weird... How long do you think your chip would take to arrive to serbia?
        • madan1
          • Nov 2016
          • 726
          • Bulgaria
          Probably I will be able to post it on Thursday or Friday.
          From BG to UK takes about a week. Serbia is closer, but I do not know how fast is your postal service.
          If you wish I can send a whole board for .. I don't know.. 10eu(?)+shipping ( or kilo slivovica ).
          By the way, why don't you try to inject 3.3 volts on the rail from external regulator or dc-dc board? Just to be sure that this is the problem.
          • sigmeyer
            • Feb 2020
            • 158
            • Serbia
            I just found this chip ... Which seems like a viable replacement... the only difference is that this is 1A instead of 500mA ... But maybe i could fit in a resistor in there to limit the output current and everything should be the same as factory. 661j on ebay
            • sigmeyer
              • Feb 2020
              • 158
              • Serbia
              Haha, im not sure if i could send sljivovica with regular mail , but trust me i would..
              Hmm i might actually try that ... I dont really have a professional lab power supply but i think the PC PSU's have a 3.3volt rail right?
              • madan1
                • Nov 2016
                • 726
                • Bulgaria
                I wouldn't use other PSU because there might be very high differences in the grounds, frequencies, etc.
                Get LD33V or something similar, connect it to the PS3 +12v rail, filter the output and inject it in the 3.3 rail.
                Keep in mind that there might be somekind of a control feedback from the original IC which, if missing could trigger error on the rest of the board... let someone more familiar with those consoles give more info.
                  • 31294
                  before you replace the chip, make sure there isnt a short between the output and ground.
                  i dont mean the chip, i mean whatever it powers.
                  • R_J
                    • 9627
                    What is the number on the replacement? Make sure it is the correct voltage. The current rating is what the regulator ic can handle, 500ma can only handle 500ma of current, a 1amp can handle twice as much current. No need for resistors.
                    • sigmeyer
                      • Feb 2020
                      • 158
                      • Serbia
                      UPDATE: OK so.... I have taken out the chip .. and that chip wasnt the one causing the problem... However... i have found the problem .. it was the chip on the other side of the board.Sure enough it had a nice big hole in it(i will upload some pictures when i get the time)..Its the IC 2502 on the schematic. On it it says sillicon village scei and some random codes on the lower part of it... On the schematic it says its confidential..
                      However i now have the 3.3volts and the short is gone... But now the PS3 stays on for a shorter time .. i dont get the really hot CPU anymore and the fan doesnt spin that fast.. and after that it goes to red light and beeps 3 times like usual... I was wondering can the ps3 work without this chip? here i found the picture of it online
                      Think i am on to something here .. but maybe im just wasting my time... btw im just fixing stuff for fun.. im not really looking to make any profit doing this.
                      • sigmeyer
                        • Feb 2020
                        • 158
                        • Serbia
                        I might actually buy that board off from you after all
                          • 31294
                          4 inductors?
                          RGBS?
                          is it a RAMDAC??
                          • sigmeyer
                            • Feb 2020
                            • 158
                            • Serbia
                            you might be correct... alot of the pins come straight from the RSX graphics chip. i think i need this chip for the ps3 to work...
                            • madan1
                              • Nov 2016
                              • 726
                              • Bulgaria
                              Tonight I will see what ps3 boards I have left and will post some photos.
                              • sigmeyer
                                • Feb 2020
                                • 158
                                • Serbia
                                Here are the photos … 2 nice holes on the chip … and i soldered back the 3.3v regulator … nice and dirty
                                • madan1
                                  • Nov 2016
                                  • 726
                                  • Bulgaria
                                  Here is the scrap board.
                                  • sigmeyer
                                    • Feb 2020
                                    • 158
                                    • Serbia
                                    Ok , cool , how much would you want for that board? i will buy it off from you, its much better cuz i dont need to order from china.. hopefully will arive within 2 weeks
                                    • madan1
                                      • Nov 2016
                                      • 726
                                      • Bulgaria
                                      PM me.. by the way, I do not know why, but the shipping rates to Serbia are insane! 15eu is the lowest price for a 0.5kg package... which makes the whole thing pointless.
                                      I think the best option will be to make a list of components that you need and I send you just them...
                                      • sigmeyer
                                        • Feb 2020
                                        • 158
                                        • Serbia
                                        Honestly i think i just need the sillicon image chip for now... I want to test some power rails that go to that chip first , but i think it was that chip that was the causing the majority of the problem... so if you could desolder that chip and send me that would be great i will pm you my info...
                                        • ebugs
                                          Asus laptop EC/SIO chip replacement
                                          by ebugs
                                          Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
                                          I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
                                          I found the EC chip...
                                          09-14-2024, 02:09 AM
                                        • Stephen
                                          A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
                                          by Stephen
                                          As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
                                          5.16V .47amp
                                          5.16V .47amp
                                          5.16V .47amp
                                          5.16V .04amp (this guy is the issue) (U3200)
                                          So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
                                          11-27-2023, 03:57 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
