Xbox One S water damage repair
  • notallbad
    • Oct 2012
    • 1190
    Completely dead, not even the fan does its initial spin.
    Psu tests ok (3 rails of 12v) and replaced anyway with a new unit.
    Cleaned up the board of dust and what only appeared to be a small amount of water damage.
    Nothing visibly looks damaged but possibly found a missing component, can anyone compare to let me know if there should be something on C7E3 (theres C7E1 through to C7E4) that appear to be smd caps alongside the main cpu with heatsink.
    Board : M1003859 Rev. D
  • reddsta87
    • Jun 2017
    • 25
    Re: Xbox One S water damage repair
    I'm working on an xbox one s mobo that has water damage too. I believe the board number is M1018156-001 Rev H. Mine does have that capacitor on the board that is missing in yours. I'm also looking for a boardview or schematic of the board to help me troubleshoot if anyone looking at this has any idea where to find one id be greatful.
    • Unspun01
      • Jun 2011
      • 349
      If you find a replacement C7E3, be sure to test and resolder C7E4 as well. C7E4 appears to have been knocked loose and has damaged solder connections.
      This damage likely happened when you took off the heat sink because there is physically no way to damage these caps with the heat sink in place.
      • ngth82
        • Jul 2015
        • 541
        C7E3 and C7E4 are part of a differential pair. Go with a 0.1uf 0402 cap.
        -Thomas
        I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        • ngth82
          • Jul 2015
          • 541
          Any update here?
          If you haven't already, try removing the large inductors and cleaning out any gunk that has accumulated due to the liquid.
          -Thomas
          • notallbad
            • Oct 2012
            • 1190
            Thanks.
            I shall try and get back to it and see how it goes.
            Will update with details.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • edugimeno
              Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
              by edugimeno
              Hi!!
              Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
              I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
              At a certain point, moving stuff around, I put all wires back in place and...
              03-24-2024, 02:31 PM
              Tankless hot water heater controller board not powering up when power is applied
              by sam_sam_sam
              I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
              I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
              However I would like to know if I could figure what happened to this controller board if possible
              Tomorrow I will take some better pictures of both side of both boards
              The...
              12-09-2022, 09:14 PM
