Hello. Does anybody know the components the xbox checks during its power up sequence?
When plugging in any xbox one, normal or "s" model, the console boots for a couple seconds then enters a power standby mode. But if a component is bad, it will try again a couple times then stop, and if you try to turn it on, then it will power itself off after a couple seconds.
I know that one component it searches for during this self check it the network chip. Does anyone know what else?
I ask since I have two consoles that do not boot, have good power to cpu/gpu and try to boot 4 times then stops. In the past I have found it to be a problem with the network chip (replacing it worked) and once being the cpu needed a reball (also worked). But these two consoles have had both things done to them and I still cannot find the error.
What else should I be looking for?
I imagine ram modules, but I can´t replace them all to find out they were not the issue. (they do have 1.5v).
