Redemption & Arcade Games
  • klkmalik
    seeking Tips
    • Nov 2011
    • 68
    • UAE
    HELLO Everyone
    Anyone interesting Amusement field Repairing.
    I searched internet There "s no forum, can start here.
    Thanks for posting.
    • 31296
    Re: Redemption & Arcade Games
    there is, but start one here anyway!
    • amigo744
      PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
      by amigo744
      Hello there,
      ps5 cfi-1016a disk console
      Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
      After the shut down the console boots up normal and then the ps4 game functions without a problem.
      ps5 games run allways without any problems after cold boot.
      Thats absolutely curious....
      I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
      That doesen´t help
      Furthermore i have opened console and renew liquid metal on gpu.
      This all doesn´t...
      06-19-2023, 05:02 AM
    • survivalbloke
      Xbox Series X - crashing to dashboard shortly after launching games
      by survivalbloke
      Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
      09-18-2024, 11:54 AM
    • paparazzo79
      Alienware 17 R3 freezing in games
      by paparazzo79
      Hi guys.
      I own Alienware 17 r3 6820HK GTX 980M.
      I purchased it recently tried some gaming (Rise of the Tomb Raider, Serious Sam) and after 10-15.min games freeze, but I could hear audio from game.
      Now I am not yet at home, but when it happens I do get separate window error message and will post it later.
      Then again there are moments when I could play for like an hour and no errors.
      From my experience reading about this issue, this means my GPU is dying, correct?
      I installed most recent nVidia drivers.
      Temp of GPU while gaming is max 76 C, but usually around...
      04-19-2024, 12:07 PM
    • GKdays
      Single capacitor replacement on arcade pcb
      by GKdays
      I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
      10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
      I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to...
      08-09-2022, 05:21 AM
    • z32KRAzY
      Alienware 15 R3 Motherboard Issues Help Plz!
      by z32KRAzY
      Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
      Laptop specifics:
      Model : Alienware 15 R3
      CPU : i7 6820HK
      GPU : Nvidia GTX 1080 Max Q
      RAM : 16GB PC4-19200 (8GB x 2)
      STOR : 256GB M.2 SSD + 1TB HDD
      Motherboard : Compal LA-D753P Rev 1.0
      Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
      08-07-2022, 06:08 AM
