Single capacitor replacement on arcade pcb
  • GKdays
    • Sep 2021
    • 6
    I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
    10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
    I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to replace it with the same ripple current
    • 31161
    Re: Single capacitor replacement on arcade pcb
    not a ceramic,
    use something like panasonic FR or rubycon YXF/YXG
    you dont have to use 10v, you can use 16v or 25v to match the diameter so it fits the board nicely.
