JBC Soldering station no power after 220v
  • xboxhaxorz
    • Jan 2011
    • 196
    Accidentally plugged it into a 220v transformer in the USA and the fuse blew, i replaced it with the 2 amp fuse and didnt get any power to it
    Did it still damage something inside even with the blown fuse?
    • 31316
    Re: JBC Soldering station no power after 220v
    post some foto's of the insides.
    something has to fail to make the fuse blow.
      master hoarder
      • May 2008
      • 12176
      If it's the JBC station I'm thinking, it more than likely has a switching power supply inside it (i.e. same type as laptops and desktops). Typically, those power supplies also have an NTC thermistor (used for inrush current limiting when you plug in the power cord to the wall). It's not too uncommon for the NTC thermistor to blow too when the fuse blows.
      However, like stj said, post some good-focused pictures, so we can point you better at what might be wrong.
        07-01-2024, 06:34 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • Ady2017
        SMD fuse soldering advice please
        by Ady2017
        Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
        11-07-2025, 12:03 PM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
