Post your worthless and/or pointless repairs
This is a sticky topic.
    replied
    Re: Post your worthless and/or pointless repairs
    Originally posted by eccerr0r
    remember 0805 4-pack resistor... so basically four 0201's next to each other!
    I did something similar on an old P3 motherboard, shown here. The resistor array there was the slightly larger size, so that's why it was easier in my case to go with 4x individual resistors.
    But these small ones on the RAM modules - I don't think they could be easily done with individual resistors and hand-soldering. Perhaps with hot air? But then might as well replace the whole array.
    With that said, here's a new idea :idea: : why not scratch off some of the solder mask from the upper trace and solder one side of a small SMD resistor there. Then, to the other side of that resistor, solder a really thin wire to go to the via or trace on the other side of the broken resistor. I've done something like that multiple times - particularly fine trace repairs and/or video cards that lost a bunch of small SMDs on the back from mishandling (not by me, though. )
  • eccerr0r
    replied
    Pictured is the smallest I have at least for conical.
    Not sure if I have a wedge tip that could heat just one of the middle pins.
    replied
    the smallest you have
    i would either use the ILS 0.2mm or a blade/knife style tip.
  • eccerr0r
    replied
    What solder tip should I use to solder a wire to the middle pins of this 0805?
    (Getting lucky to use the via or pads is not that lucky, there are none on the other side...)
  • eccerr0r
    replied
    replied
    0805? easy.
    0603 is where i draw the line.
  • eccerr0r
    replied
    FSCK there's no way I can solder wires around one resistor of an 0805 4x resistor pack... or anyone think this is even possible without shorting out the adjacent pins? LOL...
  • eccerr0r
    replied
    True I'm debating whether or not I want to sacrifice this 512M DIMM in case it too could be repaired, though technically sacrificing it for a module 4x larger is an obvious choice...
    Would be nice to find something that truly has no value.
    replied
    Not even a 4G DDR2 module...thus...worthless repair?
    If you have the time and don't feel like doing anything else... maybe not.
    I have a ton of little projects like that piling up already. Luckily, most don't take much space. Keeps me from never having a dull moment where I can say I'm bored and have nothing to do.
    Uhoh. I think I rootcaused a failure on a DDR2 DIMM,,, which means I need to desolder and replace a ogawdtootiny resistor pack... which I don't have spares of...
    No other defective RAM modules (or perhaps a dead GPU) to get one from? Even some motherboards may have such resistors around the RAM slots.
    I was thinking about soldering a ⅛W resistor in parallel to test my theory but this is way too big... not to mention signal integrity characteristics *sigh*
    I wouldn't worry about the signal integrity from slightly elongating the trace with an external resistor. Most likely, the module will still work just fine... provided you can solder that resistor on there. Now that (soldering a 1/8W through-hole resistor across the pads of the tiniest SMDs)... good luck! The pads on those SMD components are usually way too tiny to solder any through-hole components to them. Perhaps if you tried with some hair-thin wire and then solder that to the 1/8W resistor... but holy moly, that would be super ghetto!
  • eccerr0r
    replied
  • lti
    replied
    I finally got a USB cable for that video capture box. It still used USB 2.0 only, and then it died completely ("device not recognized" error).
    Also, the sample frames I posted earlier don't show how bad the video quality really is with the "USB 3.0 capable" firmware when it falls back to USB 2.0.
    If this worked, I would have attached the firmware dumps.
  • eccerr0r
    replied
    Have to mention that food safe does not neccesarily mean plastic safe... I think that's a bit of confusion in the "interwebs." Food safe means if it contaminates food, nobody will get sick. Plastic safe means it won't dissolve and destroy plastic.
    These don't have to both be true, unfortunately, so I'll have to ... ideally find one that works for both...
  • eccerr0r
    replied
    The silly thing about this RC car is that though it's crap, it's 2.4GHz and has a headlight... an infrared lamp...
    Well I had enough AA batteries, was about to scrounge 8 "dead" NiMH AA cell which is enough to power the car, and I used my bench PSU to power the transceiver*. Steering still not quite right, sticks once in a while, but I can drive the car now without going just forwards and backwards. Probably have to go and redesign the gears again slightly, the annoying thing is that the gear ratio is for the motor to generate enough torque to actuate steering tie, but a spring returns the steering back to the center. That spring has to fight the gearing, "bearings", and the motor spinning and if any of them are not spinning just right, it won't return, which leads me back to the plastic gear lubrication problem.
    Seems that people recommend lithium grease which appears to be fat based instead of long chain hydrocarbons. Sort of makes sense. Now the question is where to get a small amount without getting ripped off. Hazard Fraught Tools seems to have an 14 oz cartridge (used in full size automotive grease guns) for $4.49, and Wally World has a small 10 oz spray can for $11.69. I do wonder what the heck is up with this...
    Plus I thought the normal grease I use for my cars were lithium, except all the grease I've used for my cars were pretty much universally black...
    *transmitter and video receiver... it's got FPV sorta, figures, 2.4GHz had to be used for something.
    oh I might have lucked out, I wonder if this stuff will work:
    https://www.johnsens.com/all/4603-silicone-spray/
    happened to be in my garage, but forgotten about it. Might have to grab a piece of waste polylactic acid and soak it overnight to see what happens...
    Oh crap, no. The solvent/aerosol in this thing is NOT compatible with plastic. Perhaps if I spray some out and let it dry, and use the residue... Or in the case of the knife if I open it again, spray on metal, let it dry, and then put the plastic in it. Maybe this will work.
    Mmm... grease... or not... ? https://www.webstaurantstore.com/nob...8LUBRIGRS.html
    replied
    Now I'm pretty certain the other one will break at some point, and then I'll get the mirror image printed and pictures will be available then.
    Heh, you never know. Sometimes, those quick "temporary" repairs end up being not-so-temporary.
    Anyway onto another 3D printer project. I picked up a radio controlled toy car from the trash some many years ago, and turns out... it's broken. Steering gearbox is destroyed.
    Not sure if this too is a very valuable repair, though fortunately it's one of the medium sized cars and not one of those matchbox sized cars. It does require a ridiculous number of AA batteries of which I'll have to find some other way to power it for testing.
    Yeah, definitely not worth the repair, but still could be fun to do on a rainy day anyways.
    Actually, cheap toy RC cars played a major part in what got me interested in electronics. Thus, all that time I spent tinkering with them when I was pre-teen (and even well into teen age) has made me learn a lot about motors, torque, and gear ratios. I remember we were introduced to levers and gear ratios in an engineering elective I took in high-school. Most people had no idea what gear ratio to use when we had motorized projects, whereas all of my projects always worked on the first try. So anyways, I guess those "worthless" repairs I did on my early RC cars weren't so worthless in terms of knowledge gained.
    You can use a standard 5V power adapter if the car uses 6 AAs or less. If it's 8 or more, you can use a 12V adapter. Actually, a 5V adapter should work even if the RC uses 8+ batteries... the wheels just won't have a lot of torque and may spin a lot slower. Functions may also "jerk" On and Off if the voltage starts dropping too much. With that said, check what motor the RC has to get an idea for the current. Typically, a Mabuchi equivalent RS-260 or RS-280 motor (about 27 or 30 mm long, respectively, and 24 mm dia.) should run OK on a 3 Amp power adapter. However, if the motor is RS-360 or RS-380 size, you'll probably want at least a 5 Amp adapter for testing with the wheels off the ground (will need more if you want to see the RC drive on a surface - at least from stand-still / stalled position.)
    And while on the topic of toy RC cars, I also have picked up quite a few myself from the trash many years ago. Fixed a few of them and may end up giving to some of my nephews if they are interested.
    Anyways, I might post about them (with pictures) another time. One of them was quite garbage, but does have potential to be an OK RC car and I added some cool LED lights to it too, among other fix-ups. I also still have my RCs from back before I was even teenager. Now some of those have quite a lot of miles on them - literally. The most driven one, I think, has a few thousand easily (I used to run with it almost every day after school for 1-2 hours for at least 2 years.) The plastic bushings on the wheels are living proof - over 2 mm of play sideways and 1.5 mm of "wobble" wear.
  • lti
    replied
    The capture device firmware update fixed the audio. Unfortunately, it still won't connect at USB 3.0 (Windows says that it's USB 3.0 capable now, so it's probably a bad cable), and the compression quality is even worse (a good USB 3.0 cable should allow me to disable MJPEG compression).
    I also have a cell phone picture of what the board looks like now. I added the extra caps on the input of the WM8960G (between it and the CS4344 DAC next to it) and screwed the new diode (replacing D5 and D6) onto the heatsink.
    By the way, the firmware I had was identical to the 4MB file on that Github link. It's a 512kB Flash chip, so there are eight identical copies of the data in that dump. The 64kB file was the one that worked, and the rest of the chip is blank.
  • eccerr0r
    replied
    Dang, no pictures, it looks pretty much the same as the original except I covered up one of the fairly large holes that was used to ensure it can be injection molded. With that big hole covered up with plastic, it immensely adds to the strength of the unit and suspect this is many times stronger than the original. Now I'm pretty certain the other one will break at some point, and then I'll get the mirror image printed and pictures will be available then.
    Anyway onto another 3D printer project. I picked up a radio controlled toy car from the trash some many years ago, and turns out... it's broken. Steering gearbox is destroyed. So... 3d print gears?
    Not so lucky this time. While I think I got the gears so that the steering motor can operate the gearbox, the return spring can't reset the motor back to straight/resting position as the gears stick. Once again I need to put some sort of PolyLactic Acid compatible grease which I have no clue what I can use as lubricant, and my gears are still probably slightly off and don't mesh properly due to size (along with printing errors).
  • lti
    replied
    I have an ongoing pointless repair/mod (something that never worked properly, just like the last one). It's one of those "USB 3.0" HDMI capture devices that actually uses USB 2.0. The hardware is capable of USB 3.0, and someone found one that actually uses USB 3.0 and dumped the firmware.
    https://github.com/ArsenioDev/USB-Ca...Card-Reversing
    Those dumps are the wrong size, but it looks like the chip is mostly empty. I want to see if that firmware also fixes the audio problem I'm having. The captured audio skips ahead by a small period of time (a few milliseconds). It just sounds like a click or pop.
    The design of this thing is goofy. It converts the audio from digital to analog and then back to digital just so they can mix in a microphone input (and forgot DC blocking caps), and the HDMI output is split from the output of the video scaling chip. The output is always scaled to 1080p, but it also means that the output has HDCP stripped.
    So far, I have improved stability by replacing the diodes in the power input stage (a simple diode-OR circuit) with diodes that have a lower forward voltage.
    replied
    And more thoughts - was it worth it to fix this thing? Should have just bought a new electric knife "FRU=whole unit"?
    Maybe. Or maybe not.
    If your 3D part lasts longer than the original part, I'd say you did well, even if the time you spend doing all of that comes out to more than buying a new carving knife. But after all, what's the point of buying new stuff all the time if they'll just keep breaking. Might as well fix it once and do it right. Right?
    I like your story, BTW. Would have been cool if you had some pictures too, of course.
    Sometimes I do things just to see if can be and how difficult is it to do
    Same here... which is why I like to take on so many "worthless" repairs.
    After all, they aren't really worthless if you learn from them, and even better if you fix/restore whatever it is that needed fixing/restoring.
  • eccerr0r
    replied
    Yeah well this is the pointless and worthless repairs thread after all!
    At least I don't need to buy another electric knife anymore and finally can say I made something "worthwhile" that was truly "made" and not merely downloaded and printed...
    replied
    However recently new avenues opened and I hacked up a 3D model of the connecting rod and fed it to a 3D printer. The new PLA connecting rod fixes the problem and another broken device is saved from the landfill!
    (took me a few tries to get the 3D model just right, alas, even the third and final rev wasn't perfect. Not sure why it printed differently than seen in the slicer, but neverthess it was close enough, a bit of ripping with needle nose pliers and swiping the metal parts from the old unit resulted in a fully functional connecting rod. 6 grams of PLA needs to get sent to the trash can as prototype waste, and if it breaks again I can easily make another one! And quite possibly if the other one breaks, hopefully it's the mirror image of the one I created!)
    Ugh more thoughts - I really should put some lubricant on the "crankshaft bearing"...what is safe with both PLA (the new one) and nylon (the old one)?
    I really like the not worth repairing something part of your story
    I have done this my self making 3D parts to either fix something or to modify something and it a lot of trial and error to make it fit
    On your question about what type of oil to use because PLA is supposedly made from corn then I would think corn oil should work just do not use a lot of it or could gum it up
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
    by momaka
    03-15-2023, 10:17 PM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • bimole
    Weird behavior on 3.3V rail of a CORSAIR CX600
    by bimole
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
    02-13-2025, 04:49 AM
  • joshAU
    Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
    by joshAU
    Hi all.
    This notebook was showing no signs of life.
    I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
    However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
    If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
    I tried replacing the MOSFET with a new one, but again no voltage on the...
    05-29-2024, 12:33 AM
