Android TV box max Temp?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; do you guys know how much max temperature in F or C, should an Android tv box should be to be within safe specs?.
    i just got my Probox2 Plus and with a smal 5 V fan underneath after 6 hours of operation its temp is 131F.
    http://www.gadgetexplained.com/2017/...ore-small.html
    • 31087
    Re: Android TV box max Temp?
    that sounds insane, what is getting that hot? did you check with your finger?
    got any internal foto's?
    i will say that wifi chipsets get seriously hot.
    if your not using ethernet then you probably want to check the wifi chip is heatsinked.
    • diif
      • Feb 2014
      • 6978
      • England
      A review here http://hometheatrelife.com/probox2-ex-review/ measures 38°C and 39°C on the top and bottom.
      • dragos2009
        • Mar 2013
        • 110
        the one in the review is not the same as the one in question in the review the box has quad core cpu and here we are talking about 8 core cpu
        • Grut
          JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
          by Grut
          My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
          Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
          When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
          Can anybody help me please finding the 17MB171 USB firmware to try to upload...
          11-15-2024, 03:12 AM
        • mon2
          Hisense 55Q9G Android reset / factory firmware reload
          by mon2
          Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
          After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
          01-03-2024, 10:25 AM
        • tmcw
          Drying Oven - Preset Temp Fail
          by tmcw
          Here's an unusual one...
          This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
          It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
          However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
          01-21-2021, 03:11 AM
        • foshland
          MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
          by foshland
          Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
          Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
          External temperature (motherboard temp) is working OK, 27ºC more or less
          In windows, all the software I have tested shows correct the Core temps
          12-16-2023, 09:08 PM
        • mosfetratus
          concerning gtx675m vram temp
          by mosfetratus
          Is 98C vram temp are safe? Less demanding games goes 80ish.
          Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
          furmark goes about 104C, amperage keeps rising so do temps.
          01-30-2025, 08:41 AM
