4 Ports HDMI 1x4 Powered Splitter help.
  • ivtec
    • Dec 2008
    • 1967
    HI guys i need to buy a reliable 4 Ports HDMI 1x4 Powered Splitter Ver 1.3 Certified for Full HD 1080P,
    so my setup will be Output HDMI signal from MINIX NEO U9-H, 64-bit Octa-Core Media Hub for Android,to the 1x4 Sp-liter and connect to a 1080P Led VIZIO TV and a 1080P Phillips LCD TV and then connect also on the third port a 1080P HDMI to Composite video converter adapter;Tendak 1080P HDMI to AV 3RCA CVBs Composite Video Audio Converter Adapter,that i want to connect to my Old tube TVs that will be connected to this 1080P converter to Composite video,then from the RCA composite adapter i send the signal to a RF {radio frequency} converter throughout coaxial cable to the whole house.
    At present time i have a manual push button switch 1x2 connected with 1 TV and the 1080P to Composite video adapter and it's working great but i have to switch outputs manually every time i want to watch another TV, wish you guys build one like this 1x3 push button manually,i wouldn't mind at all see pic. Sewell Direct Ibis - 2x1 or 1x2 HDMI Bi-Directional Switch with HDCP Passthrough, 3D and 1080p Support,any insight on this from you experts,thanks
    • 31015
    Re: 4 Ports HDMI 1x4 Powered Splitter help.
    you dont need a switch, that's for multiple inputs.
    you need a distribution-splitter with multiple buffered outputs.
    electronically speaking, there is no magic there - i would be surprised if the chinese didnt have a few on ebay.
    i know they used to sell vga versions for driving multiple monitors from a single pc for shops / demonstation setups.
      • 31015
      just checked - fuckloads of them!!
      go on ebay, the magic search term is "4 port hdmi splitter"
      • ivtec
        • Dec 2008
        • 1967
        Thanks guys i just ordered this one, hope it'll work ?if not i'll return it like the previous one,amazon is five stars with returns.
        https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
          • 31015
          $50???
          the chinese would sell you one for about $15!!!
          • ivtec
            • Dec 2008
            • 1967
            Originally posted by stj
            $50???
            But i want something that works and has support and warrenty,i bought the chiper one prier to this one and it was no good,this one seems to be better,i hope.i never had lucky with the cheap ones.
              • 31015
              where do you think the $50 one is made!
              • ivtec
                • Dec 2008
                • 1967
                China.
                • ivtec
                  • Dec 2008
                  • 1967
                  Hi guys i just received this HDMI Splitter and i must say that is the best Splitter i ever have,it send video to my 4 tv Displays without a hitch.
                    When you have all 4 displays connected and running, does it adjust ALL the outputs to lowest resolution based on the display with the least capability?
                    • ivtec
                      • Dec 2008
                      • 1967
                      Yes ,if you have for example, as i have 3 1080P tvs and 1 720p tv,,if all are turned on at same time , yes it goes the to the lower resolution on all of them,but if you turn off the tv with 720P the others 1080P will go back to 1080P.
                      • Scruit
                        What is a normal composite signal range for a C64?
                        by Scruit
                        Hello all,
                        Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                        More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                        https://imgur.com/gallery/PpqcqPY
                        My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                        More detail:
                        Symptoms are that that I get...
                        04-28-2022, 05:33 AM
                      • falcontech
                        Vga to Composite-S Video Converter Startech
                        by falcontech
                        Hello
                        I have a problem with this video converter, I only have S-video output but nothing composite, I think the problem was caused by the sometimes high voltage that is found in the composite rca connectors when there is an amplifier signal and I happened to feel this tension also on my body by touching the plug...
                        04-24-2020, 08:54 AM
                        MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                        The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                        Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                        10-23-2024, 03:23 AM
                      • gizmo1990
                        What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                        by gizmo1990
                        I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                        The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                        10-21-2024, 08:02 AM
                      • Hannibal_Hector
                        Samsung UN39EH5003FXZA won't stay powered off
                        by Hannibal_Hector
                        Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
                        03-02-2021, 07:57 PM
