Turboexpress components
  • m4a2t0t
    • Mar 2013
    • 276
    I was removing a coil on the board to get a SMD cap removed and two of the pins detached from the inside of it. I also managed to wipe a cap off the board when I was desoldering the coil pins. It might be stuck in the metal pad I wipe my iron off with. When I was removing the adhesive they put on the DC jack a piece took off part of another small coil.
    Anyone know what I can do about the large coil/inductor? I have been looking for parts but I cant find any dead boards.
    Does anyone have a circuit diagram with the value of the cap?
    Does the small coil look like it needs to be replaced or can I leave it? The wire looks like it still attached.
    • 30990
    Re: Turboexpress components
    what is this board exactly?
    • m4a2t0t
      • Mar 2013
      • 276
      Its from a NEC Turbo Express Handheld.
      I found the SMD stuck to my solder braid and I talked with someone that said I could find the transformer on a SEGA game gear. If you can think of where I can find a replacement without spending $40 on another handheld. There are no damaged TurboExpress boards around right now. The non working systems sell for almost $200, recapped ones go for $400
      Where do I get the white/black adhesive that is covering parts of the board? The black stuff looks like RTV silicone. In the top left of the third pic, there was a bunch of the white stuff covering the coil and in between the SMD caps.
        • 30990
        dont use RTV, it's acidic.
        the purpose of the black is to insulate the high voltage circuits for the backlight, you dont really need it.
        the transformer, if it is like a gamegear is also a stepup for the ccfl lamp.
        so, does it work other than the backlight? because if not then you have other issues.
        • m4a2t0t
          • Mar 2013
          • 276
          I am waiting on a new DC jack and then I will be able to test it.
          • m4a2t0t
            • Mar 2013
            • 276
            Order 6v instead of 16v caps will take a few more days. Is it safe to test it out with the transformer connected?
              • 30990
              if you keep your fingers out of it
              • VaNDAL_UK
                • Aug 2010
                • 77
                • United Kingdom
                A faulty Game Gear should cost less than $10 They suffer from bad caps so the coil will be fine.
                • m4a2t0t
                  • Mar 2013
                  • 276
                  I picked up 2 game gears for $17. The Transformer worked perfect.
                  Should I cover that coil that was covered in the adhesive? Electrical tape/kapton tape?
                    • 30990
                    i wouldnt bother unless it makes a high pitch sound.
                    • Sam Scarbo
                      Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                      by Sam Scarbo
                      My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                      I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                      If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                      See the attached two pictures of the small...
                      09-18-2024, 08:29 AM
                    • User2025
                      Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                      by User2025
                      I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                      It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                      I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                      04-29-2025, 04:13 PM
                    • Endlessmist
                      Surface Pro 4 - need help with some messed up components
                      by Endlessmist
                      Hi everyone
                      Here is the case that i'm trying to solve.
                      (short intro to explain what happened)
                      I bought second hand Surface Pro 4 and when I tried to reinstall the Windows it appeared there was the password on UEFI. Seller don't reply anymore. I decided to reflash the UEFI chip to remove the password. So I need to remove the chip from the motherboard first.
                      I have basic experience of repair tablets and phones, like battery or display change. So i opened the Surface Pro 4 and removed the motherboard successfully.
                      (the...
                      04-22-2023, 07:30 AM
                    • Katz993
                      iMac Display Replacement Adhesive
                      by Katz993
                      TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
                      Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
                      03-15-2022, 10:31 AM
                    • double_DD
                      HP Probook 455 G8 charging but doesn't turn ON
                      by double_DD
                      Unfortunately I cannot/don't know how to edit my last query, so I'll create another one instead.
                      So I've received this laptop to try and fix it. There were 2 blown components - small inductor and cap, both on Vin (main power rail) on the IN pins of the 0.75V chip (SY8388RHC). I've replaced that chip and the nearby 0.75V_DEEP_SUS (same type), and of course both of blown components. There was still a short on 3V coil, which went away when I replaced PI3DPX1207C chip next to usb-c port (as it was overheating). Luckily I have older non-working 455 G7 for the spare parts....
                      03-13-2025, 05:06 AM
