ps4 hdmi
+ More Options
Posts
  • electronic-solutioncy
    Banned
    • Aug 2016
    • 19
    • 82496679322
    ps4 hdmi
    i want schematics for ps4 or way to check the hdmi output and hdmi ic
    • 30978
    Re: ps4 hdmi
    try to find a datasheet for the i.c.
      Banned
      • Aug 2016
      • 19
      • 82496679322
      Re: ps4 hdmi
      i tried but nothing thanks for the reply anybody nows the voltage output of hdmi i thing all the hdmi is the same
        • 30978
        Re: ps4 hdmi
        what is the part number on the hdmi chip?
          Banned
          • Aug 2016
          • 19
          • 82496679322
          Re: ps4 hdmi
          panasonic MN86471A
            • 30978
            Re: ps4 hdmi
            found this:
            http://www.youtube.com/watch?v=-glW2Mv-XKs
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Re: ps4 hdmi
              maybe the same videos i posted links too in your other thread
              https://www.badcaps.net/forum/showth...&highlight=ps4
              • amigo744
                ps5 cfi-1016a hdmi output graphics glitches ???
                by amigo744
                i have a ps5 here, which only produces graphic artefacts on the screen when the console shuts down.
                no graphic artefacts visible in ps4 and ps5 games.
                when the console is started, no artefacts can be seen in the main menu!
                It's all very strange and I don't know what to do next
                I swapped the hdmi port, no change.
                could it be the hdmi encoder or the components near the hdmi ports?
                how are the hdmi filters checked for functionality?
                https://youtu.be/cOCapeDOMZk
                Have anybody here same problem with hdmi...
                08-11-2023, 05:42 AM
              • Prosatanosz
                Asus B85M-GAMER no hdmi output and random restarts
                by Prosatanosz
                Hi!
                Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                10-19-2024, 05:27 AM
              • Jayanta
                Acer Nitro 5 AN515-55 no HDMI output.
                by Jayanta
                Hello, forum people.
                I have an Acer Nitro 5
                Model Number: AN515-55 Part Number: NH.Q7NSI.001
                Motherboard: Compal GH51M LA-K861P Rev 1A with 1650 Ti graphics.
                My laptop was working fine until I made a grave mistake of changing the thermal pad and paste because my laptop was getting old and pretty hot. After changing and successfully testing temperatures, I was shocked when I tried to connect my external display, a 1440p 75Hz monitor, to it. My display never showed up; it always said 'no signal.' I tried swapping the HDMI cable, using both source 1 and 2 on...
                06-17-2024, 02:49 AM
              • sebulica
                Asus FX705DT eDP and HDMI output issue
                by sebulica
                Hi
                I have an Asus FX705DT that had waterdamage....a lot
                I have managed to make the motherboard look like working but i stil have some issues and maybe someone can point me in the right direction.
                The laptop has a destroyed keyboard and the display is dead but i have managed to make the board start up and work "normal"...i have no short,power rails are looking good,hdd/ssd activity and so on.
                The problem is that there is no HDMI output,only sometimes makes the tv/monitor go black screen for a brief moment,and on the internal...
                04-06-2023, 04:44 AM
              • hinisa
                GTX 750 HDMI output not working
                by hinisa
                Hi
                I have an GTX750-FML-1GD5 with a non-working HDMI port and I'd like to figure out what's the cause and if it's easily repairable.
                GPU is working fine. VGA and DVI-D ports are also working just fine. But whatever monitor or TV I plug into the HDMI port, it isn't even recognized, let alone giving a display.
                I took a glance at the HDMI port and couldn't see any obviously broken parts.
                I've also read on various forums that some firmware versions have non-working hdmi, so I flashed dozen or so different VBIOS ROMs that I acquired from techpowerup...
                12-05-2021, 07:58 AM
