"Weird Device" : a Calculator
+ More Options
Posts
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8694
    Well, normally calculators are disposable. Alas I found this Novus 821. Before this point I never realized that this was actually National Semiconductor's consumer electronics division that actually made ... calculators. Also the really old Nat Semi logo, I finally realized it's an N and an S, I was wondering what those two squiggly squares were.
    Anyway, why this calculator was interesting? It has an LED display instead of the typical LCD!
    Alas this thing isn't working that well. What was kind of odd when I looked at the guts, this thing has NO capacitors in it at all! Not one discernible!
    Anyway I wouldn't have posted here if it didn't have problems: it, well, doesn't work 100%. First it doesn't reset on powerup, forcing me to press "C" every time. The other thing is that the LEDs go wonky. Sometimes I do wonder about the ICs in this thing, this should be a rudimentary processor with built in firmware I guess... and could the firmware actually go bad?
    It has exactly two ICs in it: MM5738N and DM8864N - and both are made by Nat Semi of course.
    Anyone have experience with these really old calculators? I guess this would be about 40 years old now... though I've had other ICs that have lasted longer than these.
  • CapLeaker
    Leaking Member
    • 8088
    Re: "Weird Device" : a Calculator
    Any pictures? Maybe have a look at the through holes if there are any???
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8694
      Yeah those two ICs are through-hole ICs - only two.
      Well I found out that the LED seems bad - I probed out the segments with my multimeter in diode check, and found a few bad segments. However I'm still not sure how the bad LED could cause the calculations to go all wonky though.
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        readout not getting to the user...
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Are the bad segments shorted? If so, perhaps this is causing the driver IC to draw excessive current and possibly messing it or its signals up to or the other IC's signals.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8694
            Interesting... don't know, so far it looks like the bad segments are open. It's just weird that the open segment is causing another, completely wrong digit (but right segment) to turn on... it would imply a short but something strange is going on. LED is a standard multiplexed configuration.
            One thing that was strange that I found: the LED display module is actually removable without solder...
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              maybe make your own 7-seg display(get pinout and get a generic display then wire it up)?
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                If I could find a 9-digit common cathode (I think) display I may have to try it, though it's a lot of wires to keep track of... perhaps finding another display would have to be the only way to test...
                I think this is pretty darn close but not sure if the HP display is the same as the NS display:
                http://www.ebay.com/itm/2x-7-segment...-/201507164881
                • fzabkar
                  • Mar 2009
                  • 772
                  There is an application block diagram for a calculator in the DM8864N datasheet:
                  Here is a datasheet for the MM5736 calculator chip:
                  ... and a patent that uses the MM5738 chip:
                  https://cdn.badcaps-static.com/pdfs/...16b20c5e00.pdf
                  The MM5738 datasheet could be in the "1977_MOS_LSI_databook.pdf":
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8694
                    Yeah the behavior is very weird. The 1977 NS databook does not contain the MM5738, but does contain the MM5737 which is close (page 345 if anyone's curious)...
                    Still no clues why it behaves the way it does with the apparently bad LED display. I wonder how much current max I can drive into the LED to test the segments, I'm sure the diode check on my multimeter is pumping less than 1mA to make sure it doesn't fry delicate junctions.
                    • fzabkar
                      • Mar 2009
                      • 772
                      The MM5736 datasheet states that "two depressions [of the "C" key] are required at power on to clear the machine".
                      I don't know why, but each calculation example begins with a "C" to clear the display register.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8694
                        interesting, perhaps the MM5738 also does not have power on reset?
                        Didn't look at the MM5737 too carefully...
                        • fzabkar
                          • Mar 2009
                          • 772
                          FWIW, the Novus 823 user manual also calls for two presses of the "C" key.
                          https://cdn.badcaps-static.com/pdfs/...3fe11bfee1.pdf
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8694
                            Interesting, so I guess it does not have power on reset. Ahh the conveniences of modern electronics :p I guess that explains the corrupt random display on startup.
                            Now what still remains is the weird behavior of digits when the LED segment is seemingly bad...
                            • fzabkar
                              • Mar 2009
                              • 772
                              The calculator chip's LED digit select outputs also double as the scan outputs for the keyboard. Could two of these signals be shorted to each other???
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8694
                                The keyboard is basically garbage, they bounce like mad. However all the buttons work - implying that there probably aren't shorts...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8694
                                  WEIRD. I had a couple segments that didn't work but suddenly they started working again... No clue. Still not perfect but it's working MUCH better now, and can do some simple calculations with it when key bounce isn't an issue.
                                  Well, pictures!
                                  https://www.badcaps.net/forum/attach...1&d=1470881866
                                  One decimal point is still not working on digit 3 from left though none of the pictures demonstrate this.
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    • Bulgaria
                                    Lol, gotta love old technology.
                                    About two decades ago, we used to have this landline phone in our house - one from the early digital era. That phone had terrible key bouncing, though. When dialing, you had to hit the keys very quickly and with just the right pressure. If we didn't, a key could register 2-5 times. As such, it typically would take us at least 2-3 tries to enter a 6 to 8 -digit phone correctly without errors . Probably the only time when I wish we had our rotary phone back.
                                    • cyberhack
                                      • Feb 2013
                                      • 466
                                      • Uk
                                      You where lucky we were poor so we had to make our own.
                                      Lol
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8694
                                        Wow, you could afford cans? I remember having to use paper cups and didn't even have enough string so we'd have to just yell...
                                        I really wonder who came up with the rotary pulse system and get it so reliable (I don't recall having it get the wrong number unless you actually chose the wrong number or "user error" not hitting the endstop), as those switches themselves are prone to bouncing too.
                                        • Loki_Fido
                                          (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                                          by Loki_Fido
                                          Hi folks,
                                          This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                                          I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                                          BIOS - XMC 25RU128CH10 (1.8v)
                                          What the heck is this? I looked all over the MB. This is the only bios.
                                          When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                                          03-20-2025, 01:57 AM
                                          APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                                          by sam_sam_sam
                                          This started a few days ago and does this about every 8 hours
                                          After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                                          The battery backup is about 3 or 4 years old
                                          Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                                          06-02-2024, 02:30 AM
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
                                        • PopcornMobo
                                          Smartbook 141 C4 not charging and only works on battery
                                          by PopcornMobo
                                          Okay so i found this Smartbook 141 C4 in the e-waste and it seemed a little too nice to just throw away.
                                          The problem comes down to it not being able to charge or work at all on the DC input.
                                          I don't know if this laptop is supposed to work on DC with the battery unplugged but it doesn't regardless.
                                          I don't have a charger for it but google says it's 5V 4A and i can do that with an ATX PSU no problem. Alas, 5V on the input does nothing.
                                          So i charged the battery with my bench supply at 2A for a couple hours and it seems to have taken some charge.
                                          Enough to power...
                                          01-20-2023, 11:49 AM
                                        • lukkihapsi
                                          Asus Vivobook X515JA Weird Boot Issue
                                          by lukkihapsi
                                          Asus Vivobook X515JA Laptop
                                          Issue :
                                          Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                          Tried :
                                          Cleaned inside for dust, applied fresh thermal paste. No Change!
                                          Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                          Removed Internal SSD. No Change!
                                          Updated BIOS to latest version. No Change!
                                          Removed battery and pressing power button for 1 minute. No Change!
                                          Weird Part :
                                          Upon turning laptop ON, screen lights up - stays black,
                                          I...
                                          07-07-2025, 12:07 PM
