PS3 motherboard - COK-OO2
  • Sadistic Taste
    • Mar 2014
    • 72
    I'm was wondering if anyone on here could help me repair this PS3 motherboard, originally when I powered it on, it shut down right away, no lights.
    I managed to figure out, that there was a short on the 12v line (IC6202 IP2003AP had shorted). I have replaced the IC, but the console is now showing the classic YLOD. I have reflowed the GPU and CPU, replaced the GPU, and still the same.
    I'm wondering what might have caused the rectifier to blow in the first place, as this may lead me to find whats causing the YLOD. I only know basic electronics, so not really sure what to check next.
    I couldn't upload the schematic, as it exceeded the upload limit.
    Any help would be greatly appreciated.
    • 31050
    Re: PS3 motherboard - COK-OO2
    maybe the proadalizer caps
    • Sadistic Taste
      • Mar 2014
      • 72
      Forgive my ignorance, but do you mean the NEC tokens? As one of them is slightly melted. I have removed a few from a scrap board, but have no idea how to test them, I only have DMM.
        • 31050
        if they arent shorted then they are probably o.k.
        read the capacitance if you have it on your meter.
        • Sadistic Taste
          • Mar 2014
          • 72
          Unfortunately, my meter can't read capacitance. I'll just have buy one.
          • Sadistic Taste
            • Mar 2014
            • 72
            I went ahead and replaced those caps, the ones I removed weren't shorted, replaced anyway, and still YLOD.
              • 31050
              if the fan is running ful speed then it may be cpu overheating from bad paste under the metal cap(that you should have removed and re-done)
              • Sadistic Taste
                • Mar 2014
                • 72
                Fan seems to be normal, I re soldered the IP2003AP, just in case I didn't attached it right, and it went back to having a short on the 12v line, IP2003AP getting really hot.
                I removed the IP2003AP, and replaced it with another one. There is a short again, but this time the resistance is 2 ohms, instead of 0.6 and it's drawing 3.3v.
                  • 31050
                  interesting device.
                  if you have it removed, check the output pad for a ground-short.
                  and check the inductor etc.
                  • Sadistic Taste
                    • Mar 2014
                    • 72
                    Do you mean the pad on the motherboard? I checked that pad to ground earlier, and it was showing around 2 ohms I think.
                    It's still attached ATM, though it won't take long to remove it. I'll get back to you shortly!
                    • Sadistic Taste
                      • Mar 2014
                      • 72
                      I removed the chip, and measured from the output pad to ground, which reads 2 ohms. Also measured across the inductor, which is showing 0.2 ohms.
                        • 31050
                        so you have a downstream short.
                        could be a ceramic cap - if your lucky.
                        • Sadistic Taste
                          • Mar 2014
                          • 72
                          OK, so how do I go about finding the cap that's bad?
                            • 31050
                            good question - usually by lifting each suspect till the short changes!
                            • Sadistic Taste
                              • Mar 2014
                              • 72
                              OK, so I removed the RSX again and the rectifier. Still short, removed the 2 top NEC tokins, found one had a short, even though I already changed them, short gone.
                              Reballed RSX, soldered back the rectifier, check short, still gone. Replaced the NEC tokins, check short, still gone.
                              Attach RSX, short returns..
                              Removed 2 top NEC tokins, still short. Removed the 2 bottom NEC tokins, short gone. The tokins are ok, no shorts etc. So I checked the pads with my meter, and I noticed from the center ground pad to the outer pad closest to the RSX, shows 2 ohms.
                              So.. Bad RSX?
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                It sounds like the RSX is bad and is causing something else downstream to short.
                                Permanently Retired Systems:
                                Kooky and Kool Systems
                                sigpic
                                • glovecaps
                                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                  by glovecaps
                                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                  11-25-2024, 04:23 PM
                                • Docus
                                  Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                  by Docus
                                  Hi everyone 😀,
                                  I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                  To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                  Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                  1. I already own the exact same model, but its plastic chassis is badly damaged.
                                  06-10-2025, 04:24 PM
                                • Archimedes
                                  HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                  by Archimedes
                                  Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                  Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                  Fans are spinning. Blindly could install windows11 and got the device manager...
                                  07-30-2024, 05:14 PM
                                  ASUS P5GC-MX motherboard recap
                                  by momaka
                                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                  So here is what the motherboard looked like with its original caps:
                                  CPU VRM area up close…...
                                  01-27-2021, 11:59 PM
                                • dragon3x
                                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                  by dragon3x
                                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                  power on.
                                  Here are some examples :
                                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                  switching supply area).
                                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                  than 6.3 V.)
                                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                  I replaced capacitors with aluminum-polymer.
                                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                  03-21-2025, 02:46 PM
