xbox 360 blowing mosfet
  • waldoalvarez00
    • Dec 2015
    • 57
    • Dominican Republic
    #41
    Re: xbox 360 blowing mosfet
    I removed the mosfets. Soldered an ATX power supply to the ground and the 5V line (output of the mosfets) and the power brick. Then powered the ATX PSU and touched the start button. Voila 3 red ligts in the ring. The error code 0031 meaning RAM not getting power (control for that comes from the same chip) also when powering up for the short while it happens I only get 0V at RAM testpoint with the multimeter. https://xbox-experts.com/errorcode/E13/0031/
    • waldoalvarez00
      • Dec 2015
      • 57
      #42
      We just ordered a pack of 5 ADP1823 chips at aliexpress for around 8 USD since now I am totally sure is the culprit. But thanks, I appreciate it. Regards. Hope the trick helps someone else .
      • waldoalvarez00
        • Dec 2015
        • 57
        #43
        See this comment in the forum
        seve91 on 2012-12-20 22:24:32 :
        reballed almost everything!!! Replaced GPU, reflowed CPU, reballed 4 ram brick
        (my model have only 4 ram bricks only on top), reballed SB, reflowed
        HANA....check Q6F1 no short. Still 0031...then replaced ADP1823 and finally
        fired up
        • waldoalvarez00
          • Dec 2015
          • 57
          #44
          Hope something else didn't damaged that chip however.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #45
            Yup, that sounds about right, then. That controller really must be bad. Hopefully it didn't take out the RAM when it went bad.
            Cool.
            Let us know how it goes and if that fixes the Xbox.
            • RudolfNta
              • May 2016
              Hi everyone..i am new to this forum. I am an engineer by profession and as per my experience PLL was use for FM radios so that when the frequency carrier started to drift a feedback circuit would correct it on the input oscillator. i think with a power supply that is frequency modulated the modulator has a tendency to drift so they are using the PLL to correct this error.
              pcb assembly cost
              • waldoalvarez00
                • Dec 2015
                • 57
                #47
                Just an update, I replaced the chip by a brand new one and nothing. Is not the chip. It is something in that circuit however. I expect this month or next one to buy an oscilloscope. Really needed for some tasks. I will keep you posted. Just for the fun of fixing this. I mean gotta be something there. a cap or a resistor or something. I hope the waveform tells me something to trace that.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #48
                  Good to hear back on this. I am still reading, so keep us updated.
                  • waldoalvarez00
                    • Dec 2015
                    • 57
                    #49
                    I should test those small SMD caps around the chip for shorts at least. Maybe some burned SMD resistor could shed some light without a scope. I have that transistor tester I modded a little bit adding some aligator clips that has ESR testing but don't think is too good. Fact is I have measured bulged electrolitic caps that have what looks good ESR (at least not altered compared to good ones) but they leak a lot (doesn't keep charge too well). I should check the QFN soldering as well. Looks good at least (visually I mean) but that format is quite problematic to solder at least for me. And not quite easy to test for shorts. Gotta buy a microscope as well eventually for visual inspections. Definitely is that circuit. It booted well (except for the BGA problems) when I putted the 5v from the ATX. I don't wanna do a reflow with heat gun cause so far I've got shorts for an XBOX 1.8v and a no power for a motherboard. Lack of expertise in that.
                    • risting
                      • Jun 2015
                      • 32
                      • macedonia
                      #50
                      I need help for jasper motherboard i read the nand 256mb without problems, damn my bad luck when start on standby mode coolrunner i is on red light after 15 sec coolrunner is off and never again wont on, no red light anymore when connect again adapter is on yellow light when connect to xbox immediately adapter go to red light before rgh console works perfectly adapter if disconnected on power back is on yellow light again when connect to xbox go to red light, i found one mosfet on motherboard short to ground see on the picture maybe smd capacitor i don't know both legs i have beep on multimeter i no remove jp and c8 capacitor !
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #51
                        The component circled in red is not a MOSFET, but rather a 3.3V regulator (LM1117-33 or equivalent, if I remember correctly.) It takes 5V standby power from the power adapter and converts it to 3.3V standby, which is then used by (H)ANA chip, SB, and I think a few other low-power ICs. It also feeds into the 1.8V standby regulator to the left of it (LM1117-18 or equivalent, IIRC.)
                        So if that 3.3V regulator is not outputting 3.3V on its left-most leg, you either have some other component shorting the 3.3V standby rail or that 3.3V reg is bad (unlikely.) Since this seems to have happened after reading the NAND, I would suggest to check all work that you have done, and particularly look for any solder bridges or damaged components that you might have caused in the process of modding.
                        Again, on a normal working Xbox 360 motherboard, you will see 3.3V and 1.8V standby from those two regulators as long as the power adapter is plugged in the wall.
                        • risting
                          • Jun 2015
                          • 32
                          • macedonia
                          #52
                          Now i no have any power on xbox no red light adapter is yellow light xbox 360 wont power on when connect power adapter this 2 regulators ST on the picture near to Nana chip for 5 sec are very hot !!! on xbox no any light i on multimeter i have short to ground to many capacitors smd electrolit caps
                          • risting
                            • Jun 2015
                            • 32
                            • macedonia
                            #53
                            On this two regulators i not see any voltage empty 0 volt on standby i desoldering from motherboard, multimeter measuring on diode mod left leg give me 750v righ leg 560v it is ok regulator or shorted ?
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #54
                              See this diagram:
                              With the adapter plugged into the Xbox, you should be getting ONLY the voltage shown in PURPLE. This means you should also get 5V on the right leg of the 3.3V STBY regulator (the one circled in purple and labeled "STANDBY POWER"). This should be happening regardless of whether the regulator is actually on the board or not, as it's a direct connection to the power brick's 5VSB rail.
                              The multimeter readings in diode mode of the regulators don't mean much. The only way to test these regulators is to either have them installed on the board and supply them with power or build a test circuit on a breadboard and see if they work (look up "1117-33" and "1117-18" voltage regulator datasheets and copy the typical application circuit from it.)
                              That said, a good test to perform with your multimeter is to set it on lowest resistance test mode (typically 200 Ohms for manual multimeter) and measure the resistance between where the arrow points to 3.3V and any GND connection on the motherboard. Do this with the power adapter -disconnected- from the motherboard. Also check the 1.8V regulator the same way. If you have a low resistance under 100-200 Ohms on any of these regulator output pins, you might have shorted something else downstream when you were performing the mod.
                              • risting
                                • Jun 2015
                                • 32
                                • macedonia
                                #55
                                Left leg i have 540 ohm right 600 ohm
                                • risting
                                  • Jun 2015
                                  • 32
                                  • macedonia
                                  #56
                                  Tnx for respond, it is possible to use regulator LD1117AS18TR IC REG LDO 3.3v and 1.8V 1.2A SOT-223 small size ?
                                  • risting
                                    • Jun 2015
                                    • 32
                                    • macedonia
                                    #57
                                    How to protect motherboard when installing rgh need resistors 100ohm before wires?
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      #58
                                      Most likely, YES.
                                      Just make sure these are "fixed" regulators - i.e. set to output only 1.8V or 3.3V. The left-side pads for these regulators on the Xbox 360 motherboard are directly connected to ground. So if you tried to use an "adjustable" 1117 regulator, you'd likely only get 1.2V.
                                      Not sure, I've never had to do this mod before.
                                      • risting
                                        • Jun 2015
                                        • 32
                                        • macedonia
                                        #59
                                        I no have voltage on this 2 regulators when adapter plugged on standby and they for 10 sec are very hot ! like grill 80c
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #60
                                          So that means whatever circuit they give power to may have a short-circuit.
                                          Most likely either NAND, Southbridge, or HANA chip could be damaged from the mod you did, if you wired it improperly. Without detailed pictures and info of what you did, I can't direct you any further where the issue could be.
                                          • Scotchmist
                                            Asus GA502D keeps blowing mosfet
                                            by Scotchmist
                                            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                            I have removed the mosfet and can run the laptop no problem
                                            The MOSFET is FDPC5018SG
                                            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                            08-24-2024, 02:23 PM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • TMTGTR
                                            An Xbox One PSU Odyssey
                                            by TMTGTR
                                            Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                            =>Background:
                                            I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                            06-17-2022, 05:40 PM
                                          • grimacelord
                                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                            by grimacelord
                                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                            10-24-2024, 12:31 PM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
