thermal fuse identification - pencil sharpener
  • clearchris
    • Dec 2013
    • 686
    So, my daughter asked me to fix this pencil sharpener. Turns out crayons dont work in a pencil sharpener. Lol.
    I have confirmed that the motor is fine, but there was a thermal fuse that burned. Unfortunately, it didnt leave much behind. I believe it was between the two terminals. If i jump the terminals, it works. Im very familiar with thermal fuses that are down in the windings of motors, but the positioning of the thermal fuse gives me pause. Its not real close to the motor.
    So, i have plenty of the common wax and spring type thermal fuses, can I sub one of those in (obviously a 110C fuse) or is there a different type that should be used here?
    Thanks!
    • 30944
    Re: thermal fuse identification - pencil sharpener
    thermal fuses are encased,
    i suspect that was just a bit of fusewire to protect from overcurrent.
    the crayon may have overloaded the motor & blown the fuse.
    btw, they DO work on crayons
    • clearchris
      • Dec 2013
      • 686
      Thanks!
      Hmm. Any guess on sizing the fuse? I can measure starting and running amps. From my research, starting amps equals locked rotor amps, so maybe a slow blow fuse under the starting amps, but above running amps?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        looks like the rating is 110 c.
        molded into the block
          • 30944
          Originally posted by clearchris
          Thanks!
          isnt the current marked on the unit?
          • clearchris
            • Dec 2013
            • 686
            Yes, it's 1.2a.
              • 30944
              so use a 2a fuse.
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • JupTec
                Thermal fuse for DeLonghi coffee machine EN 167.B
                by JupTec
                I would like to know the "thermal value" of the thermal fuse for the coffee machine "DeLonghi EN 167.B". This value is nor longer visible on the fuse itself (maby 167°C or 192°C or somethong similar ?).
                THANK YOU for your help!
                JupTec
                06-18-2024, 06:54 AM
              • Francesc V.
                Help me to identify this Thermal fuse from my sister's mixer
                by Francesc V.
                Hi everyone:
                This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
                My understanding is that it should be (NC) normally closed and open at 85C?????
                Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
                Wording in the back......... "limitor 16", "T160".
                Thanks in advance,
                Francesc....
                03-18-2025, 05:48 AM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • samtron786
                Thermal fuse AUPO P3-5A-F 250V testing
                by samtron786
                Hello everyone, how can you test a thermal fuse?
                I don't have a sign of life as an ohm or diode
                Thank you​
                11-28-2023, 08:39 AM
