XBOX 360-E model 1538, PSU pinout wanted
  • SteveNielsen
    Retired Tech
    • 2327
    I've found an XBOX console (just the console), there are no voltage indications on the board, it's a single axial multiconductor jack and doesn't appear real common, can't even find a pic of this board. I believe it needs +12v and +5vsb but no idea where to solder wires to on the jack connections so I need a pinout of the plug or jack and can't find any.
    • 31294
    Re: XBOX 360-E model 1538, PSU pinout wanted
    https://duckduckgo.com/?q=xbox360+ps...t-wt&kv=1&kh=1
    you dont try very hard
    • SteveNielsen
      Retired Tech
      • 2327
      You didn't try very hard either. Re-read my post. That is not the correct connector. It is a single axial multiconductor connector, as I clearly stated.
      I've spent the last two or three days looking so don't assume.
        • 31294
        well you didnt say it was a slim - what's the model number.
          • 31294
          try this:
          http://www.acidmods.com/forum/index.php?topic=41340.0
          • SteveNielsen
            Retired Tech
            • 2327
            That's because to my knowledge it is not a Slim, the case is not the design with the waist. It might be referred to as a Slim by some but there is nothing indcating that on the case or eslewhere. I gave the model number is in the title: model 1538.
            • SteveNielsen
              Retired Tech
              • 2327
              Thanks but that's not the same board. The power jack solder pads aren't the same arrangement and other parts in the area are different. I'm tying to get a decent pic or two but having trouble. The manf date is 2013-11-14 if that matters.
              Here's a pic (finally)
                • 31294
                pinouts are there.
                you can see the ground,
                the other heavy ones must be 12v,
                that only leaves the 5v standby and the 3.3v switching signal.
                trace those to see where they go, the 5v probably has a nice cap on it, the other is a switching signal so probably goes to a transistor.
                • dragos2009
                  • Mar 2013
                  • 110
                  • Romania
                  i think i found the solution in case it doesn't work swap 5v with pwr enable
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    Thank you guys. It's more to go on than I had
                    I didn't see any pinouts that matched my board but I'll look at that link again stj. It would be a piece of cake if I could just find a pinout of the dang power plug.
                      • 31294
                      just remember that the xbox wants 5v standby, but it only outputs 3.3v to turn the 12v on.
                      so it's NOT exactly ATX compatable.
                      you would need to add a transistor to connect the atx psu power-on signal to ground from the 3.3v signal.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        My testing ATX has the pwr-on line tied to ground and uses AC switch for power on.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          I'm not sure if that will work exactly. It's better to have the Xbox control the PSU. It's still very easy to do. I will try to make a schematic circuit of how to do that tonight or tomorrow. It's pretty easy, though. All you need is either a small MOSFET or NPN BJT and a 100-500 Ohm resistor.
                          As for the pinouts, I think what dragos2009 posted is right. Post a picture of the top of your board, though. I am a little more familiar with that since I remember these Xbox 360 slims had almost identical standby power section to the older Xbox 360s.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            Thanks for the reply. Somehow I missed it for a few days, anyway here's a pic of the top at the pwr jack. I haven't done anything with it yet. I have other PSUs I can use besides the one I modded for testing so that's not a problem.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Sorry for the late response (had some dumb uni assignments due).
                              Okay, looks like I have forgotten this board layout quite a bit indeed.
                              On the older Xbox 360's there were two SOT-232 "1117" adjustable regulators - one for 3.3V and one for 1.8V standby rails. On the non-HDMI versions, both of these regulators had their "Input" pins connected to the 5VSB supply, which went directly to a pin on the power connector. On the HDMI 360's, they added a diode before the 1.8V regulator but not the 3.3V regulator.
                              That said, have a look at "U5A1" and "U5A2" - based on some searching online, I think these should be the 3.3V and 1.8V regulators for the Standby section. One or both of these regulators should have at least one of their pins connected to the 5VSB rail.
                              So basically, put your multimeter on lowest resistance scale or continuity. Put one probe on one of the power connector pins that is NOT 12V or Ground (so that really only leaves 5VSB and PS_ON). With the other probe, see if any of the pins on those regulators reads a low resistance or multimeter beeps. If none, put probe on the second pin on the power connector that is NOT 12V or Ground. Repeat exercise above.
                              As for the Xbox 360 PS_ON to ATX PSU PS_ON circuit, I still haven't drawn that - sorry. I will do that soon, though. So hopefully if someone else bumps into this thread, they can get all of the info here.
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                Thanks. When I get the board back on the bench I will do as you say and let you know how it goes. We're doing spring cleaning and I'm focused on getting rid of useless e-junk
                                I'm curious, what is the 1.8v used for on the board?
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Okay, I finally drew the circuit - or several circuits that is. See attached image here:
                                  https://www.badcaps.net/forum/attach...1&d=1425700862
                                  Any of these three circuits should be able to "convert" the Xbox 360 PS_ON signal to an ATX PSU PS_ON signal. Actually, all these circuits are doing is simply inverting the signal (i.e. they are inverters). I haven't really tested any of them myself, but I think they should work.
                                  On the older 360's, I think the HANA used it. Maybe the onboard flash memory and Southbridge too, though I'm not sure anymore (been 3 years since I did repairs). I don't think I have a dead Xbox 360 board around here with a lifted HANA chip to check.
                                  Ah yes, that time . I need to do some of this myself. Was planning on making some shelves in my closet to store my collection of desktops and CRT monitors. But with the snow yesterday, I don't think that will be happening soon (would rather not cut any wood inside).
                                  Worst part is, when college is over in the spring and I come back home, I will have another 5 CRT monitors and 4 more desktops, among other things, to figure out where to store. These things just won't die so I feel bad throwing them away. And no one else wants to use them either.
                                  • TMTGTR
                                    An Xbox One PSU Odyssey
                                    by TMTGTR
                                    Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                    =>Background:
                                    I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                    06-17-2022, 05:40 PM
                                  • Satdude
                                    Xbox 360E won't turn on after voltage regulator shorted
                                    by Satdude
                                    Hello, I have a Xbox 360E Stingray where the 3.3VSTB regulator shorted and put 5V on the rail. I think the RAM and eMMC are on this rail. After replacing the regulátor, I get proper 3.3V but the console won't even turn on. Seems the eMMC is dead, I get power to it just fine but JRunner doesn't even detect the console when I hook up my PicoFlasher. Does a dead eMMC/NAND cause the console to not even turn on? Also does this with the eMMC removed, planning to downgrade it to 16MB NAND but want to know if it's a useless effort to save this motherboard. Thanks
                                    08-28-2024, 03:55 PM
                                    HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                    09-12-2024, 02:00 PM
                                  • grimacelord
                                    Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                    by grimacelord
                                    Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                    After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                    I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                    10-24-2024, 12:31 PM
                                  • Stevedb
                                    Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                    by Stevedb
                                    Hi all
                                    I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                    Pasw netcomchetumal.
                                    Enjoy it.
                                    Greetings Steve
                                    From Belgium...
                                    04-04-2023, 12:42 AM
