PS5 Edm-010 No Power - Help identifying missing capacitor
    Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
    It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
    When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
    I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached). I am a relative novist when it comes to these things so I'm hoping someone can confirm if these pissing caps can cause this no power issue, and if so, would anyone know a part number so I can order replacements?
    Thanks for your help!
    1uF 10V
      Thank you! Any idea what size it would be? It looks like it could be a 0402 but it's hard to say. Also, in your opinion, would this cause a no power issue? Thanks again!
        Yes, 0402. 10mA could point to SB area (check there for shorts) But first replace the caps, fuse and check power draw again.
