PS5 Hardware Winbond Firmware
  • JinMoriCAP
    • Feb 2025
    I have a PS5 Disc Edition where the flash memory was defective. I bought a matching Winbond component and flashed it both with the old extracted .bin file and one from the internet (where I adjusted the serial number). The PS5 starts up again, but I can't reinstall it with the .pup file on my USB stick. I get the error message "Something went wrong." I would appreciate your support.
  • HBTECH
    • Dec 2024
    • Brazil
    I have the same problem with an EDM-033 on a CFI-1214A. I replaced the Winbond with the corresponding file, but after a while it malfunctioned again. The cooler starts and turns off. After that, when you press the power button, the blue light comes on and beeps 3 times and turns off. After a while, it turns back on, and after a while, the same malfunction occurs again. I re-soldered the BGA on the CXD and after that it lasted much longer, about 3 or 4 weeks, and then the malfunction returned. Could this be a possible BGA solder defect on some other component, or should I replace the CXD on the equipment?
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
    • Daniel Larsson
      Firmware file for Marantz NR1501 needed
      by Daniel Larsson
      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
      The content of these seems to be useless as far...
      05-23-2025, 04:11 AM
    • GeckoGreen
      Samsung service bulletin: need firmware file for PN63C550 TV
      by GeckoGreen
      I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
      You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
      The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
      Will you please help me get the [2D63]LOGIC.bin file for my TV?
      05-17-2025, 02:47 PM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
