What resistor ohm will work better to repair this waterpik?
  • artvandalai
    • Nov 2024
    • 26
    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    take a wire off the motor then it wont burn .the copper on the board is already burning .
      • 31077
      your pump is stalled ir atleast gummed up
      • redwire
        • 3910
        Something strange is the blackened PCB trace only runs to the filter cap, not to the motor.
        Don't these pumps get dead-headed and I'm not sure if a pressure relief valve is there or the resistor is supposed to limit pressure?
        edit: oh this thing runs on mains
        • redwire
          • 3910
          cross-posted, yeesh:
          https://www.eevblog.com/forum/repair...this-waterpik/
          https://www.eevblog.com/forum/beginn...e-should-i-use
          https://www.electro-tech-online.com/...esistor.166190
          https://forum.allaboutcircuits.com/t...sistor.201146/
          also related thread here (it's got a TCO as well
          https://www.badcaps.net/forum/troubl...-water-flosser
          • artvandalai
            • Nov 2024
            • 26
            Did not know you were on these other forums also. Is this a crime?
            • redwire
              • 3910
              Your resistor question goes back 7 months ago.
              What's the problem - many people have helped you and told what resistor to use, things to check for.
              Yes it's a crime - you post more information, pics on other forums which makes it hard for us to help you here. Expecting many to help you for free on these forums, you already have your questions answered- why waste our time?
              https://forum.digikey.com/t/need-hel...sistor/41781/2
              • artvandalai
                • Nov 2024
                • 26
                How much do you charge? Im not forcing you to help out or to reply to my post, why derail my post?. Ive changed the resistor to the same specs of 47ohm 2w and the resistor still blows. The video i linked showed using a 56ohm resistor instead to help with any extra resistance from any wear on the device but I wanted to know what the people of this forum would suggest instead before buying what i need from digikey.
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  did you cut the motor wire yet and then seen if that fuse resistor still burns ? this cant get any easier . its not like its even close to 1st of april .
                  • redwire
                    • 3910
                    Stop blaming the resistor - it is not the problem. They don't burn up unless they are overloaded. This one has a safety aspect- it must be a fusible type so this does not burn down the house.
                    It (high current draw) could be a problem with the motor, its brushes. Another site you posted on gave links to buy a new one for $10.
                    Or the pump mechanism needs lube or has dirt in it. Look for a mechanical problem. Buy a 24 pack of these resistors.
                    • artvandalai
                      • Nov 2024
                      • 26
                      An update on this, i sold this waterpik for parts so its one less worry on trying to fix. Thank you all for the help.
                      • artvandalai
                        • Nov 2024
                        • 26
                        What wire are you suggesting desoldering to test if the resistor still burns or not?
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          one going to the motor not that it matters if you did sell it
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • SluggerB
                            Help with 2002 Ford Ranger blower motor
                            by SluggerB
                            So I picked up this little truck, and the blower motor does not work correctly. There are 4 settings, Low, Med-Low,Med-High, and Max. The issue is Low, Med-Low, and Med-High ALL act like Low. Max works like Max.
                            So research tells me it is the resistor block for the blower motor. So I change that. Still works the exact same. More research tells me the plug going into the Resistor block often gets corroded and faulty, so I change that. Still works the exact same. More research says sometime the switch in the cab goes faulty. I replace that. STILL WORKS THE SAME.
                            From...
                            11-10-2022, 04:58 PM
                          • BOSCHNJAK
                            by BOSCHNJAK
                            ABOUT ME INTRODUCTION FILE
                            2
                            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                            2022 BEV, PROJECT ?
                            2021 BEV, PROJECT ?
                            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                            12-28-2023, 02:09 PM
