Originally posted by artvandalai
View Post
What resistor ohm will work better to repair this waterpik?
Originally posted by petehall347 View Post
did you cut the motor wire yet and then seen if that fuse resistor still burns ? this cant get any easier . its not like its even close to 1st of april .
An update on this, i sold this waterpik for parts so its one less worry on trying to fix. Thank you all for the help.
Stop blaming the resistor - it is not the problem. They don't burn up unless they are overloaded. This one has a safety aspect- it must be a fusible type so this does not burn down the house.
It (high current draw) could be a problem with the motor, its brushes. Another site you posted on gave links to buy a new one for $10.
Or the pump mechanism needs lube or has dirt in it. Look for a mechanical problem. Buy a 24 pack of these resistors.
Originally posted by artvandalai View Post
How much do you charge? Im not forcing you to help out or to reply to my post, why derail my post?. Ive changed the resistor to the same specs of 47ohm 2w and the resistor still blows. The video i linked showed using a 56ohm resistor instead to help with any extra resistance from any wear on the device but I wanted to know what the people of this forum would suggest instead before buying what i need from digikey.
Originally posted by redwire View Post
Your resistor question goes back 7 months ago.
What's the problem - many people have helped you and told what resistor to use, things to check for.
Yes it's a crime - you post more information, pics on other forums which makes it hard for us to help you here. Expecting many to help you for free on these forums, you already have your questions answered- why waste our time?
https://forum.digikey.com/t/need-hel...sistor/41781/2
Did not know you were on these other forums also. Is this a crime?
Originally posted by redwire View Postcross-posted, yeesh:
https://www.eevblog.com/forum/repair...this-waterpik/
https://www.eevblog.com/forum/beginn...e-should-i-use
https://www.electro-tech-online.com/...esistor.166190
https://forum.allaboutcircuits.com/t...sistor.201146/
also related thread here (it's got a TCO as well
https://www.badcaps.net/forum/troubl...-water-flosser
Something strange is the blackened PCB trace only runs to the filter cap, not to the motor.
Don't these pumps get dead-headed and I'm not sure if a pressure relief valve is there or the resistor is supposed to limit pressure?
edit: oh this thing runs on mainsLast edited by redwire; 01-05-2025, 09:42 PM.
take a wire off the motor then it wont burn .the copper on the board is already burning .
The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 PhotosTags: None
