PS5 EDM-033 - 2 sec BLOD - CPU and RAM not coming up
  • groomit
    • May 2023
    • 29
    Bought a defect console eager to repair.
    Seller was not very communicative.
    Upon arrival I noticed UART Pads had been soldered previously.
    Read it out and got:
    80810001 General power failure (periphery, GDDR6, APU, data line shorted)
    F*CK. Had That before with a chipped APU. But this APU die looked good. However I found flux around it - previously reflowed?
    Boot sequence is quite right 325 mA dropping to 9 mA.
    Using the thermal camera I can see the SSD controller and South bridge getting warm.
    But APU and RAM stay cool (=not initializing?).
    Could find no shorts on the SSD controller.
    But nearly all Caps from all RAM ICs read dead short.
    APU rail also measures quite short.
    Except for a totally shorted APU, what could I look out for?
  • groomit
    • May 2023
    • 29
    Hmm, found something. The rail from attached picture is dead short (marked red). Is this the RAM rail?
    The mosfet measures fine.
    When injecting voltage only the direct contact point on the rail is heating up.
    Internal short on PCB?
    • BwE
      • Dec 2024
      • 12
      You have a short near F7002, that code you got is wrong/misleading.
      • groomit
        • May 2023
        • 29
        Hi BwE,
        Nice to read you here. I appreciate your work related to console debugging. Please excuse that, as a hobbyist and Linux user, I didn't use your tool with the proper code database.
        However, I did quite extensive short checking on various caps - maybe I missed one.
        Dou you think this could relate to the mentioned VRAM rail being shorted(=dead short)? I don't see a direct path.
        • BwE
          • Dec 2024
          • 12
          Im not on my PC now so I can't manually look up the code again. It's a 1.8v short? I'll edit this post later if I remember sorry!
          • groomit
            • May 2023
            • 29
            Think I'm getting somewhere. One of the tantalum caps measures dead short. Never had them fail before. Maybe because of the low value short and the black colored housing it didn't stick out on thermal camera?
            BTW. what are healty APU power rail resistances? If I'm not mistaken there are two phases. Shoud both measure the same?
            • groomit
              • May 2023
              • 29
              Okay - success!
              The APU power rail was shorted over one mosfet. Was quite a hassle to isolate the faulty one :-D.
              Finally I got picture :-)
              Just noticed a typo in the title. It was a EDM-031 board. But only difference should be digital vs disk version.
              • ongobongo
                • May 2023
                • 69
                How have you handled the fault finding? I have aN EDM-020 with the exact same problem, power rails read nearly short and SSD:/Southbridge start up when powering on but APU/memory is not booting. Did you desolder the DRMOS one by one or is there are better way to do this?
                • MadMaxGR
                  • Dec 2020
                  • Cyprus
                  Originally posted by groomit
                  Okay - success!
                  Can you specify which MOSFET was at fault? Maybe pin point on the board? That will help the community.
                  • aandrade
                    • Oct 2021
                    • 6
                    • Chile
                    Okay - success!
                    You can explain the mosfet that repaced? please
                    • aandrade
                      • Oct 2021
                      • 6
                      • Chile
                      did you solve this problem? I have the same one
                      • WTF_Tech
                        • Mar 2020
                        ps5 turn on blue light then off, I found a dead shorted mlcc capacitor Near f7502.
                        replaced it machine fully works and is soak testing now.
Name:	ps5 blue light then off.png
                        • ryancog
                          Lenovo Legion 5 Pro 16ARH7H Short On "5V Always-On" Rail
                          by ryancog
                          Hello there,
                          I've got a Lenovo Legion 5 Pro 16ARH7H (AMD Ryzen 7 6800H, NVIDIA RTX 3070Ti) that seems to have "developed" a short on the 5V "Always-On" rail.
                          Background
                          I don't have too much in the way of useful information here, I don't think. This laptop has been used for the past few years without any notable issues/incidents. The laptop is often "docked" w/ the AC adapter (Lenovo's rectangle one) connected. A few days ago, I finished up working on things in the evening, and the next morning I found the laptop off w/o any...
                          04-20-2026, 10:50 PM
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                        • blazie151
                          Intel NUC, completely lost, short after a simple CMOS battery removal
                          by blazie151
                          My buddy's fiancé was told to just keep her equipment after switching jobs, which included 2 nice Dell monitors and an i7 NUC (NUC11PAH aka RNUC11PAHi70Z00) with a bios lock. Seeing that there was a CMOS battery cable, I unplugged it, waited a few minutes, then plugged it back in. After that, I got a green stand-by light, and the power button did nothing. So, I tried hooking up to the bios with a CH341A (black version with 3.3v mod) and could not read it at all. In every program except IMSProg, it showed chip not detected, and in IMSProg, it showed up as a completely wrong chip (which happens...
                          03-29-2026, 04:06 PM
                        • Elementallion
                          PS3 CECH-2001B (DYN-001) shuts down after Vcore rise – VRM debug, no short found
                          by Elementallion
                          I’m troubleshooting a PlayStation 3 Slim CECH-2001B, motherboard DYN-001, and I’m stuck at a fairly deep VRM-level issue.
                          I’ll try to provide as much structured information as possible.
                          🔧 Initial problem
                          Console behavior:
                          • Press power → green light for ~1–3 seconds
                          • Then shutdown with beep and blinking red
                          • Fan barely starts spinning
                          This looks like a typical early power fault / YLOD-type shutdown, but I’m debugging at board level.
                          🔍 Measurements and observations
                          🔌 Power rails
                          • 12V rail: stable, no drop during
                          03-23-2026, 09:32 PM
                        • Stephen
                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                          by Stephen
                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                          02-06-2025, 12:03 PM
