Xbox One X Psu
  • Viktor Árvai
    • May 2024
    • 32
    • hungary
    Xbox One X Psu
    Hi I have a question about an xbox on x psu model1815 rev1 , Every time i plug it in it trips the housebreaker and the fuse inside. On the high voltage side almost everything is shorted to ground , on the 12 v side no short on main leads and nothing in general.
    My question is what is the most common part that can cause this, i figured ill try it here first before i start pulling off everything.
    Thank you!
    • 31007
    post some pictures,
    in theory that shoudnt be possible because it should have blown it's own fuse!
    • Viktor Árvai
      • May 2024
      • 32
      • hungary
      Strange yea , it blows its own fuse and the circuit breaker soon az plugged in. Where i marked with red that side is completly shorted to ground, but the 12 volt is seems to be ok.
      • Viktor Árvai
        • May 2024
        • 32
        • hungary
        Where the 230V comes in there is no short on the live and neutral when there is no fuse installed if the fuse is installed there is a short between live and neutral.
        Also i have changed q205 with not an exact match i have put on a 5cw insted of 5b , i have been told there should be no problem.
          • 31007
          yellow disc in heatshrink is a MOV - they can short out, other than that, the bridge rectifier can short out
          • Viktor Árvai
            • May 2024
            • 32
            • hungary
            Mov Was good after that i started to pull of components it turns out this sucker was the boss of the organisation.
            iam assuming its a cap ,leads are shorted, after removing short is gone on the high side.
            but there is still some shorts that i dont think its suppose to be.
            ill go further into it and post it thank you for your help!!!!
            • Viktor Árvai
              • May 2024
              • 32
              • hungary
              the area in the black square is still shorted to ground i suspect the 4 pin mostfett in the middle because its directly connected to the removed thermistor, ill remove it tomorrow i dont have any solderwick left.
              ill keep you updated thank you for the help!!
                • 31007
                the green part is an inrush limiter, it's supposed to be low-ohms and as it heats up the resistance drops even lower
                • Viktor Árvai
                  • May 2024
                  • 32
                  • hungary
                  so if i understand correctly this can be a potential cause for poping fuses and tripping circuit breakers?
                  should i try just changeing this part? i dont want to damage it further, and as i wrote there is a section what is still shows as short and that is directly connected to this limiter .
                    • 31007
                    the green part is probably fine, what is printed on it?
                    like i said, check the bridge rectifier - a 4 wire pack of diodes that has AC mains going in and dc going out to the big capacitor(s)
                    • Viktor Árvai
                      • May 2024
                      • 32
                      • hungary
                      the green part is 15s1r3m it should be 1.3 ohms and that is the reading i get.i have pulled the rectifier its a gbu608. the left and right pair of legs have connection to each other so 1 to 2 and 3to 4 where is no connection it mesures 0.8 megaohm like from 1 to 4 or 2 to 3, i think this should be alright.and i find a rectifier diode LT7b30 s3j and this is shorted from both sides.
                      on the line that goes from the rectifier dc to the big cap i still have a short
                      c8a is shorted i pulled it of it show 2.6 nf dont know that suppose to be ok or not .but after removing the short was still there.
                      • Viktor Árvai
                        • May 2024
                        • 32
                        • hungary
                        i think the rectifier is bad i have followed a tutorial and it seem that this one is busted.
                          • 31007
                          a rectifier is 4 diodes, each diode should have a voltdrop of around .4 to .6 in one direction and be open-circuit in the other direction.
                          no pins should be shorted in any combination.
                          • Viktor Árvai
                            • May 2024
                            • 32
                            • hungary
                            Its definetly toast , ac pin is shorted to positive . Can this short kill something on the 12v side?
                            • Viktor Árvai
                              • May 2024
                              • 32
                              • hungary
                              i got a new rectifier installed now the high side is okay but where the 12 volt starts there are some shorts in fact the whole line is shorted what goes into the big cap.
                              also the s3j rectifier diode is also toast that connects the 12v + from the rectifier to the big cap.
                              maybe one last tip what most likely burned?
                              Thank you for your help it was really a big help , its my first psu repair so i really have no ide what is what.
                              • Viktor Árvai
                                • May 2024
                                • 32
                                • hungary
                                forgot the picture sorry everything marked is shorted to ground.
                                  • 31007
                                  check D10 on the under-side
                                  • Viktor Árvai
                                    • May 2024
                                    • 32
                                    • hungary
                                    0.411 voltage drop from one side and ol from other
                                    • gcrezz
                                      GameConsoleRezz
                                      • Jul 2024
                                      • 14
                                      Typically I will not repair a PSU in these side they are so inexpensive to replace. However, if you are intent on fixing it, I suggest looking at the pwm ICs and any of the 3-legged fets and mainline high voltage caps. Your fault is likely on the low side. I've never seen a short on the high side in any psu before. If your still unable to find the short, I suggest using a thermal cam.
                                      • Viktor Árvai
                                        • May 2024
                                        • 32
                                        • hungary
                                        Thanks for the reply, im still waiting on a diode, i had not got to time for it , i will go on to the low side high side is fixed i will update if ill find anything , ill check the pwm ics and mostfets thanks for the tip.
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • Stevedb
                                          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                          by Stevedb
                                          Hi all
                                          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                          Pasw netcomchetumal.
                                          Enjoy it.
                                          Greetings Steve
                                          From Belgium...
                                          04-04-2023, 12:42 AM
