Spooky2 XM signal generator dead.
  • fuzzy4
    • Jul 2024
    • 18
    Was working fine, but now dead, tried different power supply and still the same.
    No noticeable marks on the circuit board.
    The only possible issue I can think of, was that I wasn't using the switch on the unit to turn it on/off, I was using the wall socket (For a few months), because I thought the switch was getting a bit loose.
    What info do you need to try and troubleshoot?
    TIA
    • 30978
    you may have answered your own question.
    lets investigate the switch, how it connects and how it's mounted.
    • fuzzy4
      • Jul 2024
      • 18
      Thanks, here's a picture.
        • 30978
        external power - so is the psu good?
        if it is, shoe a picture of the bottom of the board so i can see the tracks from the power inlet
          • 30978
          is it this?
          https://www.spooky2.com/newmodel/
          • fuzzy4
            • Jul 2024
            • 18
            Bought standard external psu (5v 2A) brand new and tested with multimeter, so pretty sure it's good.
            Yes, that's it.
              • 30978
              thats very clear tracks
              so plug your psu in and meter the voltage at the switch pins to see if it switches properly.
              you can get ground from the bnc sockets
              • fuzzy4
                • Jul 2024
                • 18
                From top to bottom, pins 1, 4 & 5 are fluctuating, 2 & 3 are ~5v
                  • 30978
                  now i'm confused, the switch only has 3 pins unless your counting the mounting lugs
                  but it sounds like it's powered,
                  so we need a higher resolution pic of the topside so i can read chip numbers
                  • R_J
                    • 9535
                    That voltage would be correct with the switch in the OFF position, Change the switch to the ON position and you should have +5v on your so called 3 &4 pins
                    The pins 1 and 4 are just the switch mounting and are not part of the spdt switch contacts
                    • fuzzy4
                      • Jul 2024
                      • 18
                      Ok, changed switch to ON and I'm getting a fluctuating reading on pin 3. (Yellow arrow)
                        • 30978
                        put some solder across the switch contacts to force it on.
                        if that works we just need to find a switch with the same pin spacing
                        • fuzzy4
                          • Jul 2024
                          • 18
                          "put some solder across the switch contacts", can you explain please?
                            • 30978
                            join the yellow and orange arrows in RJ's picture
                            • fuzzy4
                              • Jul 2024
                              • 18
                              Yes that worked, it powers up.
                              • CapLeaker
                                Leaking Member
                                • 8095
                                Take that switch off the board, take it apart, clean it and reassemble. Then test it before you put it back on the board.
                                • fuzzy4
                                  • Jul 2024
                                  • 18
                                  Not confident in doing that, is it a bad idea to permanently connect the two terminals, so that it's always on?
                                    • 30978
                                    no problem with that at all
                                      • Jul 2011
                                      • 6033
                                      Or just put an external switch and be done with it if you can find the exact replacement switch
                                      • fuzzy4
                                        • Jul 2024
                                        • 18
                                        So if I wanted to replace the switch, it has to be like-for-like?
                                        Why?
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • estabilito
                                          Nintendo Switch Oled dead
                                          by estabilito
                                          Hello, i bought dead nintendo switch oled.
                                          after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
                                          I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
                                          After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
                                          I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
                                          05-07-2024, 03:48 PM
                                        • cappernicus
                                          Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
                                          by cappernicus
                                          Laptop model: Sp513-54n-74V2
                                          Testing power rails (separated by chip) reveals:
                                          19V_DCBATOUT - (active)
                                          5V_AUX_S5 - (active)
                                          5V_S5 - (active)
                                          3D3V_AUX_S5 - (active)
                                          3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
                                          1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
                                          1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
                                          1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
                                          09-25-2024, 05:19 PM
                                        • CapLeaker
                                          Shelly plus 1 dead, does not switch
                                          by CapLeaker
                                          Anyone got any Shelly remote devices around here?
                                          I’ve got a few of these and they were all working fine for about a year. Today I noticed that one of them that controls a single light switch isn’t working at all. I mean it’s so dead, even the light switch doesn’t control the relay. No clicking, no anything whatsoever. Unfortunately it’s in the basement in a dark room and trying to get it out is going to be interesting. Maybe there is some carnage in there, who knows. It was hooked up to power mains.
                                          The other exact same one is in the same room,...
                                          10-05-2023, 04:42 PM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
