Nintendo Switch-No Shorts and not charging
  • nebulink
    • Apr 2024
    This is a strange one for me. I have a Nintendo switch that turned on initially. The BQ chip was getting very hot. I unplugged and tried a different battery in case there was a problem with them one that came with it. I was told that the battery had been swapped.
    After trying a new battery, the unit would not turn on.
    Ammeter shows 15v 0 amp draw.
    Tested around BG, P13 and M92. No shorts. Decided to swap out BG. Same result.
    Checked voltages around BG, M92 and Max 177050.
    Also checked Max 177621.
    Getting desperate, I changed M92. Nothing
    I changed both Max chips, nothing
    Unit is not in RCM mode.
    I also took a working board and started checking values all over the board in diode mode and could not see any discrepancies.
    I am at a loss with this one. Any suggestions would be greatly appreciated.
  • Mysterex_
    • Jul 2023
    what about the 3.3 volt regulator located above the audio IC, any shorts on this rail as its fed from the BQ chip and supply's power to the m92/P13 and wifi/bluetooth module ?
    • nebulink
      • Apr 2024
      Voltages all look good and no shorts around this area. This is very odd. Maybe my M92 replacement was bad. It just doesn't make any sense.
      It would be nice to no the complete circuit for charging to help isolate the issue.
      • chickenhawk88
        • May 2024
        • 86
        • US
        https://www.retrosix.wiki/first-stage-boot-short-checks
        • gcrezz
          GameConsoleRezz
          • Jul 2024
          • 15
          If the BQ was what was getting hot, why did you not try replacing that? Or is that what you meant in your post when you said you swapped out the "BC"?
          • nebulink
            • Apr 2024
            Correct, I did replace the BQ.
            • SebasVergaraP
              • Jan 2026
              Did you find any solution? I’m facing the same issue, I have all voltages except VBAT, but BQ is new (tested multiple IC) but still nothing, and same as you, everything looks normal from the values on diode mode.
              • SebasVergaraP
                • Jan 2026
                I’m sharing the solution to this problem, hoping it helps someone else in the future!
                The Symptoms:
                • Console turns on and functions perfectly.
                • USB-PD negotiates 15V, but there is 0A current draw.
                • Battery shows as connected/charging in the OS, but the percentage only drops.
                • Hekate reported "Input Current Limit: Error" and "Input Wattage: 0W".
                • M92T36 and BQ24193 had already been replaced, but the issue persisted.
                The Troubleshooting: Even though I had already tried two brand-new BQ chips, I decided to do a deep dive into the voltages and diode mode readings on the following pins:
                • Pin 1 & 24 (VBUS): Should match input voltage (5V or 15V).
                • Pin 23 (PMID): Should match input voltage.
                • Pin 22 (REGN): Should be approximately 6V.
                The Discovery: On Pin 22 (REGN), I noticed a very slight voltage drop. It wasn't a dead short, but the voltage was low enough to prevent the IC's internal logic and gate drivers from functioning.
                The Fix: I replaced the BQ24193 for a third time. After installing the third chip, the REGN voltage stabilized, the console immediately began pulling current, and the "Input Current Limit" error in Hekate disappeared.
                Moral of the story: Don't always trust "new" chips from your supplier. If your REGN voltage isn't correct, the BQ is likely defective!
