DJI FPV goggles, dead backlight
  • snowphish
    • Oct 2015
    I have a pair of DJI FPV Goggles v2 that the backlight on one side LCD screen does not light up. Obviously I have tried already to switch screens and ribbon connectors, it's not that. I've inspected things under a microscope and can't see anything wrong with the connector or otherwise.
    This is the pinout of the LCD - and I am reading about 35v on LED anode on one side and lower 30V on the non-working side, but this is without the LCDs connected.
    Now there's no information on these boards, it's using a proprietary CPU - I've been trying to pinpoint where the backlight power comes from and I think I found it here in these 2 circuits, one for each LCD
    The qfn IC is marked 1N=7L ... this seems to be a Richtek marking scheme, but looking through all the references I could find I was not able to determine what chip it is. Maybe something like this one but ... maybe not... I will try to see if the pinouts make sense
    Anyone has leads on how I should approach this?
    I'm thinking I will swap the ICs - so if the problem switches sides, at least I know I'm dealing with a dead IC - and I guess I probably won't be able to find a replacement unless I find other donor goggles.
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Gjackson
    50PUS7555/12 Backlight no picture
    by Gjackson
    bit of a weird one today,
    Got this set with just backlight no picture, sound etc.. works fine so mainboard and PSU are likely good. I think it's a bad panel but don't know if it's fixable, here's why:
    T-CON voltages all present when both LCD ribbons are disconnected but if both are connected then most of the rails are gone (ex. VGH, VGL, HVDD)
    If only one of the ribbons is connected, I do get a hazy picture from the respective side but there is a loud hum coming from the T-CON board due to what I suspect is overcurrent and the circuitry that generates...
    11-04-2024, 02:48 PM
  • Lee M.
    IR night vision goggles to find shorted panel line?
    by Lee M.
    Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
    11-10-2023, 03:19 PM
  • Audeze
    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
    by Audeze
    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
    Does...
    10-06-2024, 08:54 PM
