Sega Genesis 1 - No mono audio output
  • ohmmy
    • 182
    Re: Sega Genesis 1 - No mono audio output
    Originally posted by budm
    Sounds like it if you do not even hear anything at all. Another test is to check the DC voltage at the output pin of the LM358, it should be around 1/2 of the Vcc power supply voltage.
    Ok vcc is 4.8v and output of lm358 is 2.48v
    So now I'm confused. Is it bad?
      That is correct voltage, the op-amp is being used in single power supply instead of bi-polar (VCC +, VCC -). To use OP-AMP in single power supply, they have to bias the + input pin at 1/2 of the VCC so the output will be set at 1/2 VCC, so as far as the DC voltage is concerned, it is OK.
      • ohmmy
        • 182
        I see. So can it still be bad even if the voltage is correct? Should I replace it or?
          You can have correct DC but can still be bad IC.
          Another thing you can do is to take the Left and right channel outputs from the hedphone jack pin 3 and pin2 by using 1k resistor on pin 3, 1k on pin 2, the ends of those 1K will be joined together to make it into mono signal, then feed that into C30 negative leg, the negative will have to be lifted off the board, put the other caps back in place. The volume of the headphone will have to be adjusted. That should work to verify the circuit.
          • ohmmy
            • 182
            Do I have to use the resistors? Don't have any lying around
              Yes, you do, they are needed for isolation.
              • ohmmy
                • 182
                Ok and this is bypassing the lm358 chip right?
                  We will be using the headphone audio outputs to drive pin 8 input pin of IC13 instead of 358, just be sure to lift the negative leg of the cap which will be the leg we will put the signal to.
                  • ohmmy
                    • 182
                    Ok, picked up some 1K resistors and did what you suggested. Still no audio. Does this conclude ic13 is at fault?
                    Weird that I didn't get any audio when tying caps c30 c31 together like you instructed me to do previously. Maybe I didn't have volume up loud enough on tv, I don't know
                      Something is not making sense here at all, we did that cap tying together, I have you do this headphone mode just to make sure you did not do the first experiment wrong. Well, we can also use the headphone amp to simulate the buffer amp inside IC13.
                      We also did bypass IC13 output by feeding the signal from 358 to the cap that feed the scart and you still did not get the sound, you can try that using the output of the headphone to feed the cap C31 again.
                      You did turn the volume of the headphone up, right?
                      • ohmmy
                        • 182
                        Oops! volume was down on headphone out! Good thing I still had it wired. Ok yes, now there's audio out
                          Whew!, Ok, so we use the headphone amp to drive the input of the IC13 and you get sound, that means the 358 is not working.
                          • ohmmy
                            • 182
                            Sweet I can get that cheap on eBay.
                            I'm curious if you don't mind explaining, why were 1k resistors used instead of other values? Also, for future reference how could the headphone amp be used to simulate the buffer amp in ic13?
                              1K give enough isolation of the Left and Right headphone power amplifiers so the output of one amplifier will not affect the output of the another amplifier. If signal of one amplifier is out of phase, one output will try to go high, another output will try to go low, then the amps will buck each other and can damage the output stage. With 1K, the current will be very low not enough to cause problem. If you tie two outputs of the amplifier directly together, if the signals feedings were out of phase, you will damage the amplifiers.
                              Btw, if you can live with this setup, I would leave it in case you do the damage to the board during removing/installing the IC.
                              • ohmmy
                                • 182
                                Ah ok. Thanks. So if we wanted to bypass the LM358 and ic13 using headphone amplifier would we just tie in to positive of c31?
                                  OK, let get this correct, we use the L and R output of the haedphone amp and feed the INPUT PIN 8 of buffer amp through cap C30 negative pin, at first you indicate that you still do not get any sound, but it turns out to be that the headphone volume was not turned up.
                                  So then I was going to suggest you to bypass the IC 13 buffer amp and use the headphone to drive SCART coupling cap C31 to see if you will get the sound.
                                  But now we know that the IC13 is good but the 358 is not putting out any sound to pin 8 of IC13, so 358 is bad.
                                  • ohmmy
                                    • 182
                                    Yes correct and I just ordered a 358, but I was just curious for reference/knowledge if I ever encounter a similar problem.
                                    Would I bypass ic13 same exact way I bypassed 358 using the two 1k resistors except this time feeding into c31's positive leg lifted off board?
                                      Right now we bypass the 358 only.
                                      But lets say that the IC C13 buffer is bad, then you will use the Headphone amp outputs (through the isolation resistors) to drive the SCART (C31 +) and the RF modulator (you have to lift R72/ C87 junction off the board and tie it to C31 +). This will bypass both 358 and the IC 13 buffer amp, we cannot use the 358 to directly drive the SCART (which we did) because it does not have enough power to drive the SCART/MODULATOR), so the headphone amp become both a mixer amp (358) and the buffer amp (IC 13 audio buffer), in this case the resistors may have to be drop down to 500 Ohms or so.
                                      • ohmmy
                                        • 182
                                        Thanks so much, I appreciate the help and patience in putting up with my inquisitions. Great help. I'll post back results of changing the 358 when it comes in.
                                          No problem, glad to be able help.
                                          • kotel studios
                                            Lantec PULSE 386 subwoofer - no audio output
                                            by kotel studios
                                            Hi
                                            I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
                                            After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
                                            The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
                                            Yesterday, 04:15 AM
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • mecha1166
                                            Copper corrosion? Yamaha HS8S Audio 1 output only
                                            by mecha1166
                                            OAUD Yamaha HS8S Audio one output only.
                                            I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                                            08-04-2023, 02:55 PM
                                          • dicky96
                                            Denon AVR-X500 No audio output
                                            by dicky96
                                            Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
                                            I only have 2x 8ohm speakers attached to Left and Right front.
                                            If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
                                            I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
                                            02-22-2022, 08:36 AM
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
