Caps for DC blocking in Playstation 1.
  • blakey72
    • Mar 2013
    Hi. I've removed the original DC blocking Caps after the DAC in the PS1 and now need to replace them with 2 100uF or equivalent Non-polar caps (so the guide says). There are so many on the market I really don't know where to start. I've read that Panasonic and Rubycon are good. Any suggestions. Here's the guide I'm following:
    http://www.dogbreath.de/PS1/output/output.html
    Cheers
    Blake.
  • ReverendJones
    Resurgam
    • May 2010
    • 49
    Re: Caps for DC blocking in Playstation 1.
    I have used Panasonic SU series in quite a few pieces of audio equipment with good results.
    Digikey - Panasonic SU, 100uf 16v
    Panasonic SU datasheet
    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
    • Logistics
      • Apr 2007
      • 721
      I don't have the patience to read that page in detail, right now (too much sugar in my system) but it appears all this mod does is take the line-level signal from the DAC and bypass the internal output stage to exit directly through the RCA jacks. If this is so, then I would try two things: First, just try it without the filter caps. Why? Because most anything you output it to is going to have it's own input filter caps as a safeguard against offending devices who don't utilize output caps. Second, if it does end up being a problem without the output caps then I would decide against using internal output caps, rather moving them out-board. Why? Because this way physical size is not a problem. And since this appears to be only line-level and not an amplified signal, it's not likely that you need something as gigantic as a 100uF capacitor. As an example, one of my heavily modified SbLive! soundcards had a 10uF electrolytic between the DAC and a line-level preamp IC which I changed to a 0.47uF polyester film with no adverse effects--in fact it only improved the sound, but with no capacitor I had crazy noise so it WAS NECESSARY, but the 10uF was not warranted. My point was going to be that I would update the output capacitors to a film since they sound so much better than electrolytics and they become quite physically large above 0.47uF so moving them outboard, perhaps into a small break-out box would be ideal. Especially, since every device reacts differently/requires different values of blocking caps and you could play with different values on a given device.
      If you insist on using a bipolar electrolytic then the Panasonic SU which RJ suggested would be my recommendation as well... although, I think Digikey has two values of Nichicon MUSE ES in stock, one of which happen to be a 10uF IIRC and that would be fine, too.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
