Caps for DC blocking in Playstation 1.
+ More Options
Posts
  • blakey72
    • Mar 2013
    Hi. I've removed the original DC blocking Caps after the DAC in the PS1 and now need to replace them with 2 100uF or equivalent Non-polar caps (so the guide says). There are so many on the market I really don't know where to start. I've read that Panasonic and Rubycon are good. Any suggestions. Here's the guide I'm following:
    http://www.dogbreath.de/PS1/output/output.html
    Cheers
    Blake.
  • ReverendJones
    Resurgam
    • May 2010
    • 49
    Re: Caps for DC blocking in Playstation 1.
    I have used Panasonic SU series in quite a few pieces of audio equipment with good results.
    Digikey - Panasonic SU, 100uf 16v
    Panasonic SU datasheet
    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
    • Logistics
      • Apr 2007
      • 721
      I don't have the patience to read that page in detail, right now (too much sugar in my system) but it appears all this mod does is take the line-level signal from the DAC and bypass the internal output stage to exit directly through the RCA jacks. If this is so, then I would try two things: First, just try it without the filter caps. Why? Because most anything you output it to is going to have it's own input filter caps as a safeguard against offending devices who don't utilize output caps. Second, if it does end up being a problem without the output caps then I would decide against using internal output caps, rather moving them out-board. Why? Because this way physical size is not a problem. And since this appears to be only line-level and not an amplified signal, it's not likely that you need something as gigantic as a 100uF capacitor. As an example, one of my heavily modified SbLive! soundcards had a 10uF electrolytic between the DAC and a line-level preamp IC which I changed to a 0.47uF polyester film with no adverse effects--in fact it only improved the sound, but with no capacitor I had crazy noise so it WAS NECESSARY, but the 10uF was not warranted. My point was going to be that I would update the output capacitors to a film since they sound so much better than electrolytics and they become quite physically large above 0.47uF so moving them outboard, perhaps into a small break-out box would be ideal. Especially, since every device reacts differently/requires different values of blocking caps and you could play with different values on a given device.
      If you insist on using a bipolar electrolytic then the Panasonic SU which RJ suggested would be my recommendation as well... although, I think Digikey has two values of Nichicon MUSE ES in stock, one of which happen to be a 10uF IIRC and that would be fine, too.
      Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
        EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
        by momaka
        I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
        So, here is the...
        06-06-2020, 04:39 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
