CFLs
  • linuxguru
    • Apr 2005
    • 1564
    CFLs
    I took a look at the electronics in the base of a generic, el-cheapo Compact-Fluorescent Lamp (CFL) after it died. Sure enough, there was a burst electrolytic in there - 2.2uF, 250v - one of two caps in series after the mains bridge rectifier. The circuit is a minimal self-oscillating half-bridge topology, with transformer-driven base drive to two 13001 bipolar transistors - very similar to most PC PSUs, except that instead of a load transformer there's just an inductor, blocking capacitor and the two CFL filament loads, forming a series-resonant load.
    I replaced the two primary 2.2uF, 250v no-name caps with Sam-young SXE (I know it's crap, but it's better crap than what it replaced) and the lamp came back to life immediately. It appears that the limiting components w.r.t endurance in el-cheapo CFLs are the electrolytics - replace the electrolytics with 105c non-aqueous types, and it's entirely possible that the driver electronics will outlive the CFL tube.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: CFLs
    i wound up with 100+thinlite ballasts that had complaints of flicker.a major rv mfr i fix stuff for gave them to me for parts.
    on each and every one was a 1000mfd 35v axial lytic that was open.it was a weird name i had never seen before.like chen hong or such.
    fixed all of them.
    us solar users like free 12v dc stuff!
    • Jason616
      22uf 250v non polarized cap
      by Jason616
      I cannot find these anywhere .
      Does anyone know where I can purchase theses caps ?
      I'm very limited on space so I cannot make my own out of 2 polorized caps nor use a polypropylene cap since it's package size is to big to fit in the allowed space.
      So wondering if anyone has any info on where I can purchase the following caps
      22uf 250v non polarized radial leaded capacitors
      11-27-2021, 01:18 AM
    • cap__
      Can I replace 15uf capacitor with 22uf?
      by cap__
      "If I wanted to replace an old 15uF/400V capacitor with a new one,
      I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
      11-29-2023, 11:16 AM
    • Perry Babin
      Derating of polymer electrolytics
      by Perry Babin
      There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
      If they require derating, why would the manufacturer give them their rated voltage?
      This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
      https://www.mouser.com/datashe...
      10-24-2025, 11:57 AM
    • Perry Babin
      Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
      by Perry Babin
      I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
      This is for the primary side of a switching power supply in a car audio amplifier.
      Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
      10-16-2025, 05:20 AM
    • Gadjet
      Looking for a Fuse T4AL/250V
      by Gadjet
      I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
      06-15-2025, 09:16 AM
