PS3 and 34XBR960
  • weirdlookinguy
    • Sep 2007
    • 1638
    PS3 and 34XBR960
    I recently bought a PS3 and slammed a 750GB HDD in it. I just got home yesterday and finally got to hook it up and I couldn't be happier, it's a slick little system and Uncharted 3 is dope (too bad the beta ends today!)
    It looks fantastic on the Panny plasma downstairs. Unfortunately, my Sony 34XBR960 HD tube doesn't seem to like the new PS3 as much as I do. I get a black screen through HDMI. I remember it also didn't like my old Philips upconverting DVD player through HDMI before I got an LG blu-ray. I think it might be an HDCP issue.
    Any suggestions? Or should I start saving for a 50" Panasonic 1080p plasma?
  • PlainBill
    • Feb 2009
    • 7034
    Re: PS3 and 34XBR960
    A little research might give you the answer. Your idea of an HDCP issue is logical. The service manual is available at Elektrotanya. I have seen instructions for updating HDCP information on other TVs, but I've never dealt with this model.
    Instead of saving up for a 50" Panasonic, how about saving up for this one? It should give you bragging rights for quite some time.
    PlainBill
    • Village Electronics
      OldPro
      • 118
      Output 1080I limitation?
      • digge
        • Apr 2006
        • 296
        I doubt HDCP is active while playing games, think its only active while watching blueray? Dont quote me on that though but seems not needed to have HDCP while playing games to me.
          OldPro
          • 118
          Blue ray can output 1080P. I think that model can not play 1080P. It is limited to HD in 1080I or below. I don't know what your set up is but most blue ray machines are switchable between the both formats.
          I do not think there is any copy protection problem. If you know how to switch the PLAYER to 1080I or below, it would be worth the attempt.
          • digge
            • Apr 2006
            • 296
            Came to think of something related that might be of use to you. I had a friend with a manual HDMI switch that was only working reliably for one monitor and not the other (2 port switch). Turned out my friend had bought cheapo HDMI cables and they were actually not fitting snugly enough to make good contact. Sure is a long-shot but would be quite easy to borrow the cable from downstairs if you didnt use the same one.
            I however thing like the others that your TV and PS3 dont get along due to some miss-communication about resolution your TV is capable of. Set it up for 720p and see if that makes the picture show.
            • weirdlookinguy
              • Sep 2007
              • 1638
              You guys are correct, my set supports 720p and 1080i. No 1080p.
              I set the PS3 for 480p and I still had the same problem, sound but no video. I'm using the same cable upstairs and downstairs, the Panny has no problem but the Sony just isn't having it.
              I bought a component cable and it works, but the picture quality is a far cry from the tact sharp plasma downstairs. For the first time ever, my big Sony tube let me down. I'm so dissapointed with the image quality that I think the component cable is going back to Fry's and when I get back home for good in August I'm going to start looking for a cheap broken LCD/Plasma on Craigslist to fix.
              • weirdlookinguy
                • Sep 2007
                • 1638
                I scoured the service manual and there's no mention of HDCP anywhere. Thanks for the link anyway PlainBill, that is great to have.
                Google shows that a lot of people have had issues with the HDMI on this TV acting funny. Apparently the fix is to replace the board that has the HDMI plug on it. No thanks.
                • ArMaaN376
                  Samsung PS51E550 Plasma TV
                  by ArMaaN376
                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                  Opened TV cover & observed foll
                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                  How to confirm Y -Buffer board...
                  06-19-2024, 04:05 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • KYBOSH
                  Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                  by KYBOSH
                  Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                  No picture but you hear the TV static (white noise) playing loud and clear.
                  The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                  But it seems they didn't get too far and just left it.
                  When I first took a look I was amazed at how pristine the inside looked.
                  Its as if the TV had been in a time capsule.
                  Caps looked like they were just pulled off the self.
                  Copper coils had no sign of corrosion on...
                  02-01-2023, 11:10 PM
                • porfyriadhs
                  Samsung Plasma PS51D6900DS Bootloop
                  by porfyriadhs
                  Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                  Thanks a lot !!
                  10-19-2023, 11:31 AM
                • Yanleb
                  Schematic or datasheet for Plasma TV buffer chip
                  by Yanleb
                  I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                  So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                  Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                  05-18-2022, 01:36 PM
