Need Help Identifying Capacitor On Kar-Tech Versa Remote
  • grimacelord
    • Jan 2017
    • 380
    I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
    One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters.
    Does anyone have any idea what the full values for this capacitor is? Obviously, it seems to be 200mF, but I have no idea what the voltage is or type of capacitor it is.
    Thank you.
    Attached is some pics
  • R_J
    • 9559
    Re: Need Help Identifying Capacitor On Kar-Tech Versa Remote
    That is a current sensing resistor, 200mΩF 2512 0.2R 1% 1w
    Digikey RL73H3AR20FTDF, check if the size is correct
      • 31094
      interesting.
      can you meter the resistance of a few of them? see if they are all under an ohm?
      i think they could be shunt resistors for monitoring current.
      if they are then you need to trace where the burned one goes because it probably go hit with an overload from a bad part or shorted wiring
        • 31094
        beaten to it because i was looking at the pictures too long
        • grimacelord
          • Jan 2017
          • 380
          Thank you!
          • redwire
            • 3910
            You could beep out multimeter on continuity the burnt resistor going to what connector pin, to see which load is shorted out.
            Resistors never burn up on their own - they get overloaded and burn up by a problem somewhere else...
            To me it looks much bigger than size 2512, OP would have to measure its size.
            • R_J
              • 9559
              This is too small based on the other components (BTS5215L) in the picture, it is likely a 4527, 5 or 7 watt
              Here is a datasheet that lists the size
              Here is a KOA 5Ω7watt 4527 picture, the marks etc. look the same as the 200mΩ
              There also must be a short somewhere that caused this sense resistor to burn, Find out what this line controls and check that circuit.
              • redwire
                • 3910
                The output driver IC's are high-side Profet BTS5215L.
                They are protected switches so I don't see what the sense-resistors are about, other than being the fuse here.
                I don't like this soldering either.
                  • 31094
                  sense resistors can detect problems for fast shutdown.
                  like open motors/relay-coils/cabling
                  or overload caused by something jamming
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • Joe24
                    Genius Ultramatic R2-T3 remote,Need help identifying component
                    by Joe24
                    This is out of a wireless (RF) remote for one of those power lift beds for seniors. Remote says "The Genius Ultramatic" on it, and is model #R2-T3 (03-680252-03), FCC ID: MG8-R2-T. Standard Motorola MC145026P encoder, which is functioning.
                    I'm told the unit doesn't work. I don't have the bed that goes with it, so maybe it's the remote that's the problem, and maybe it isn't . . . Haven't actually found anything that's NOT working in it yet. Don't have a receiver, so can't verify that it's actually transmitting anything. However, when I hold the device near unshielded...
                    07-13-2022, 01:26 PM
                  • Ambro
                    Help identifying missing smd capacitor for HP elitebook 840 g3
                    by Ambro
                    In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
                    I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
                    I've attached a picture of where it's located on the board.
                    Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
                    Thank you for any help you can provide....
                    09-09-2023, 06:21 PM
                  • krob80
                    PS5 Edm-010 No Power - Help identifying missing capacitor
                    by krob80
                    Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                    It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                    When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                    I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                    05-15-2025, 04:24 PM
                  • chunk69
                    Looking for help in identifying Kuang Jin capacitor from PSU
                    by chunk69
                    Hi friends,
                    I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
                    Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure....
                    12-06-2023, 04:35 PM
