PS4 with BLOD - Getting UART enabled ?
  • orion78fr
    • Apr 2022
    • 37
    • France
    Hi everyone !
    So a friend gave me a ps4 to rescue but it just pulses blue and never boots. I can't get it to safe mode either (maintaining the power button never gives a second beep, except after like 15 seconds to force turn off). Nothing visible on the board and removing the hard drive doesn't change anything (SMART data are OK on PC).
    I'm trying to enable UART on the PS4 to get info on what it stops on, if a memory is bad, something is corrupted... as explained here : https://repair.wiki/w/PS4_UART_Guide
    However, the software that everyone used, "BwE PS4 NOR Validator", went paid in early 2023, at a hefty price (155€ / 165$), and without any trial (because it was abused).
    There is no single use price or something like that, and it seems everybody relied on this only software. I can't really pay this much for one PS4, especially if it's just going to tell me that a memory bank is dead and I can't do anything. And I probably don't need all the extra features the validator offers (because it's probably a physical problem, the ps4 was stored in a drawer for months before this incident).
    So, my goal is to find a way to enable this UART flag in the NOR without this program. It's probably a simple flag to enable if I have the correct offset and flash back on the NOR. I have found some leads in a program called ps4-permanent-uart that lists offsets for the flags for different firmware versions : https://github.com/JTAG7371/ps4-perm.../uart_helper.h
    The problem is that I'm unsure of the version of the PS4, and if I can use these offsets directly on my dump.
    Hope you can help me !
  • orion78fr
    • Apr 2022
    • 37
    • France
    Re: PS4 with BLOD - Getting UART enabled ?
    Okay guys ! So it has been a few days and I managed to find an old version of the BwE PS4 NOR Validator that I successfully used to enable UART on the PS4. I won't link to it directly (as I don't want it to be taken down, it's useful stuff) but I can give it to you via private message if you need it.
    I don't know if it can be done on all versions on the same offset, but for my BIOS version (ps4 dump checker identified it as firmware 1.62.0000 ?), it changed the FF at 1C931F to 01, according to HxD (it's in an FF block, so the address seemed random, but it worked).
    So now that I have UART enabled on the PS4, I can look at the logs. I tried to use pins 2 & 5 on a serial port on an old Dell D600 on linux but didn't manage to make it work, I don't know why (I've set the correct baud rate of 115200 but I seem to only get garbage).
    I have a CH341 that have another mode than bios dump (written something in chinese TTL on the back) that I can change with a jumper and gives me a COM port on my PC, I just had to connect the TX & GND points of the PS4 to the RX & GND points of the CH341 and use PuTTY.
    So what did I get ?
    "ERROR: DCT[0] is disabled" "ERROR: DCT[1] is disabled"
    Which means the first bank of RAM is dead.
    However, putting pressure on the ram with my finger, it managed to boot correctly. I even put a game disk and played for 15 mins, no problem...
    ... until I walked a bit too hard near it and it crashed (with an MC4 corrupted message or something like that).
    I think a ram chip has a cracked solder ball or something like that, I'm going to reflow them and see.
    • orion78fr
      • Apr 2022
      • 37
      • France
      Hi again !
      I've had some people reach to me in PM for the validator, but I've found an open source alternative to the Bwe NOR Validator : https://github.com/andy-man/ps4-wee-tools
      So first thing, I can confirm that the UART flag is indeed at 0x1C931F : https://github.com/andy-man/ps4-wee-...ls/nor.py#L116
      So you can easily edit this with an hex editor to 01 to enable UART, but this new tool eases the process, can validate part of the dump too (I think ?) and provide more useful info.
      Second thing is that I need help. I think I'm at the limit of my hot air station alone.
      The ps4 motherboard is notoriously already hard to unsolder from (for hdmi repair), but for the RAM chips, even at 480°C and full blast for what seemed like minutes, the solder balls doesn't seem to melt (tapping the corner with my tweezers doesn't make the chip dance on the pads).
      Do you know how I can do this more easily ? I suppose the problem is that the board is huge and dissipate a lot of heat, more than the hot air station can easily provide.
      Maybe putting something on it to prevent too much heat dissipation ?
      Maybe using another heat source to assist the hot air ? (would a hair drier on the back of the board be enough ?)
      Maybe putting the board on top of these kind of thing while using hot air ? :
      • Mario875
        • Jun 2023
        • 15
        • Far Away
        What hot air station are you using? What airflow and temps also? Are you using a nozzle to direct the heat?
        All of these will have an affect on how well you can get heat into the board, not to mention 480*c on a cheap station is not the same as 480*c on a Quick, Weller or similar.
        A pre-heater will always help, but I would go for the PUHUI T8280 over what you have posted above (the PUHUI can usually be picked up cheap 2nd hand), it is large enough to heat up the full board so then you only need a little bit of additional heat from the top to get things to de-solder.
        No, a hairdryer will NOT do anything, so don't waste your time with that.
        • scorpionfadi
          • Mar 2018
          • 6
          • syria
          So what did I get ?
          You must replace the RAM according to the attached picture
          • orion78fr
            • Apr 2022
            • 37
            • France
            Thanks for the confirmation, I already saw a crop of this image.
            The RAM on the opposite side of these are part of the same bank right ?
            • chp
              • Mar 2023
              • usa
              hi, orion78fr.
              I have same issue(BLOD) with you. Try to enable UART, still not working.
              I tryed with "ps4 wee tools" and refered to https://repair.wiki/w/PS4_UART_Guide.
              My ps4 is NVG-002 pro model. fw version is 10.50.
              Can you share me "BwE PS4 NOR Validator"?
              • pavlo13
                • Sep 2023
                • Ukrain
                Hi orion, could you send me the BwE ps4 nor validator old version with trial period. Thanks in advance!!! My e-mail: pavlo13g@gmail.com
                  • 30970
                  or use the free software
                  https://github.com/andy-man/ps4-wee-tools/releases
                  • maverick78
                    • May 2018
                    • Italy
                    Hi, can you post the free version of the software? I already tried PS4 Wee Tools v0.8.7 but it doesn't work. Thank you.
                    • Mr.Ultimate
                      Dell Precision 5540 - Absolute / Computrace permanently enabled. Need bios fix to disable
                      by Mr.Ultimate
                      Hi, I have Dell precision 5540 laptop from old workplace,decommissioned old stock. its a good spec laptop i9-9880H etc, so I decided to keep it and use it for personal purposes.
                      I was checking bios settings and I found that Absolute (Computrace) is permanently enabled/activated, and field is grayed out, unable to change it to disabled/deactivated state. The laptop status is clean, absolute has no any warnings or messages booting pre-bios pre-OS or post booting, while using laptop, im just not feeling safe having absolute permanently enabled having backdoor on a bios level enabled to my...
                      08-06-2024, 05:24 AM
                    • Gjackson
                      Ps4 Pro long blue light of death
                      by Gjackson
                      I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
                      08-21-2023, 02:41 PM
                    • kitor
                      HP Pro Mini 400 G9 - Led code 3/6 Processor does not support an enabled feature / disable AMT in dump?
                      by kitor
                      Hey,
                      I got HP Pro Mini 400 G9 waiting for a long time for a CPU. Bought I3-12100T which is on supported list just to receive code 3,6 which says "Processor does not support an enabled feature".
                      After research I found this is most likely due to all the management stuff being enabled in BIOS (it has vPRO essentials I5 sticker so that is very likely) where 12100T definitely does not support it.
                      Unfortunately I wasn't able to find any friend who would have and lend me their CPU to fix that... so the question is, can this be changed at bios dump level?
                      I attached...
                      02-03-2025, 11:09 AM
                    • spleenharvester
                      Synology MR2200ac mesh router, UART connection - login details?
                      by spleenharvester
                      This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
                      I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
                      Code:
                      sudo minicom --baudrate 115200 --device /dev/ttyS0
                      09-02-2024, 01:19 PM
                    • cappernicus
                      Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
                      by cappernicus
                      Laptop model: Sp513-54n-74V2
                      Testing power rails (separated by chip) reveals:
                      19V_DCBATOUT - (active)
                      5V_AUX_S5 - (active)
                      5V_S5 - (active)
                      3D3V_AUX_S5 - (active)
                      3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
                      1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
                      1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
                      1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
                      09-25-2024, 05:19 PM
