Xbox one Controller No Power
  • mike123333
    • Oct 2011
    • 196
    Hello I have an xbox 1 controller 1708 that has no power and upon diagnosis there are major shorts around the ARM X905893 002 BGA chip. My first time working on this device. can this chip be replaced or is it paired to the board?
    Thanks MJ
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Xbox one Controller No Power
    I've mixed top boards with bottom ones so no, not paired.
    Definitely a short and not low resistance ?
    • mike123333
      • Oct 2011
      • 196
      you maybe correct, when I connect the top board with the joy sticks to the main board, the two circled IC chips get extremely hot, the one on the left is worse than the right one. I check for shorts and find shorts on the large caps. When I remove the top board the shorts are gone and I have voltage on those chips.
      On the top board with the joy sticks I have short to gnd on the caps and resistors circled. I do not have a good board to check if those components are low resistance or shorts.
      • aktinson
        PS Lover
        • May 2023
        • 18
        • Bulgaria
        Hey MJ,
        Just wanted to drop a quick thank you for posting about your Xbox 1 controller issue way back when. Even though it's an old thread, it's been incredibly helpful in troubleshooting my own controller woes.
        Your detailed descriptions of the problem and the steps you took in diagnosing the issues provided excellent guidance. It's great to know that the ARM X905893 002 BGA chip can be replaced and isn't paired to the board.
        Your work on this issue has undoubtedly helped many others like myself who've stumbled upon this post in search of solutions. So, a big thank you for sharing your knowledge with the community!
        Best regards.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          Tankless hot water heater controller board not powering up when power is applied
          by sam_sam_sam
          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
          However I would like to know if I could figure what happened to this controller board if possible
          Tomorrow I will take some better pictures of both side of both boards
          The...
          12-09-2022, 09:14 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
