Asrock Z77 Extreme 4 full BIOS .bin request please
  • tbone8
    • Oct 2013
    • 10
    Howdy,
    The short, I have an Asrock Z77 Extreme 4 motherboard I picked up on the ebay to see if I could fix. I have some i7-3770 CPU's (all are good) and popped some DDR3 1333 memory in and get the dreaded F4 code along with the 55 code. Upon powering up, just keeps attempting to start, fan runs then restarts in a seemingly never ending loop. Cleared the CMOS multiple times, no effect. So, would like to try my new Christmas present to myself, a XGecu T48 (TL866-3G) Programmer to reprogram the IC. I assume this is a fairly popular board and hopefully someone will post the full .bin file.
    The long, I started repairing electronics as a hobby around 10 years ago and this site is one of the first that I cam to to read about failing capacitors, thank you to the host. Anyway, have repaired a lot of radios, hifi gear, test gear, etc and now have evolved to motherboard troubleshooting/repair. Have watched a bunch of vids from "Learn Electronics Repair" channel and learned a ton. He has done quite a few repairs via BIOS IC reprogramming so I am attempting to stick my toe in that repair realm.
    Evidently, one cannot just download a complete BIOS .bin file from the manufacturer, that would be too easy. So, I am humbly requesting a copy of said file so I can have a project for Christmas. I ordered a few IC's (W25Q64FVAIQ) from the interweb is case mine is bonkers and a XGecu T48 Programmer from the Amazon.
    Thanks and look forward to the input!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Asrock Z77 Extreme 4 full BIOS .bin request please
    You can.
    55 is RAM-related error btw.
    • lotas
      • Jan 2016
      • 4459
      • Russia
      Code -55
      "The Memory could not be detected. Please re-install the memory and CPU. If the problem still exists, please install only one memory module or try using other memory modules."
      • tbone8
        • Oct 2013
        • 10
        Originally posted by piernov
        You can.
        Hi, where can one download the BIOS?
        I know the 55 error is ram related, I pulled ram out of working pc, have 4 sticks, all give 55 error. In the dozens of threads I read about this similar issue, the 55 error resolved after BIOS was corrected. Will try some other DDR3 ram tomorrow hopefully that I have from other working computers.
        Thanks!
        • lotas
          • Jan 2016
          • 4459
          • Russia
          This error can also be due to the processor itself, since the memory controller is located in the processor itself or bent legs on the processor socket.
          • tbone8
            • Oct 2013
            • 10
            Indeed, good to know. I inspected the CPU socket, no bent pins fortunately. Thanks for the post.
            • piernov
              • Jan 2016
              • 4435
              • France
              Manufacturer's website.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11213
                • Viet Nam
                Thanks!
                https://www.asrock.com/mb/intel/z77%20extreme4/#BIOS
                Rename Z77EXT42.90 to Z77EXT42.bin
                • tbone8
                  • Oct 2013
                  • 10
                  Thanks, two questions.
                  Is this a complete BIOS or an update? In the go by thread on this site, there is no mention of Asrock systems.
                  Second, I read about the renaming file thing, I assume one needs certain software to open and reformat it to a .bin file?
                  Pardon the ignorance...
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11213
                    • Viet Nam
                    That's complete bios file.
                    Just rename on windows but you need a programmer to wite that file into your bios chip.
                    • tbone8
                      • Oct 2013
                      • 10
                      Ok, will give it a try. Got my programmer from the Amazon today.
                      • tbone8
                        • Oct 2013
                        • 10
                        Fiddeled with the T48 programmer this evening. Read the chip and saved a copy of the file. Right clicked on the flash file from the website, added the .BIN and used exam diff to compare both files and they are not identical. So, gotta figger out how to program the old ic with the new data and hopefully she fires up!
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11213
                          • Viet Nam
                          I don't know if your backup was successful or not or just a junk file but just different versions, they have a lot of differences even though they are all virgin bios.
                          • tbone8
                            • Oct 2013
                            • 10
                            There was a sticker on my chip with a v 2.9 label so likely it is the version I am attempting to install. Hopefully will post results soon!
                            • tbone8
                              • Oct 2013
                              • 10
                              Update! Got the new BIOS IC's from the China today. Programmed one and sure enough, the motherboard has come to life!
                              • oxygensys
                                • Jun 2020
                                • 8
                                • Sri lanka
                                thank you
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • paulwal
                                  Updating a BIOS on ASROCK
                                  by paulwal
                                  Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
                                  https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
                                  I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
                                  CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
                                  Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
                                  It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
                                  10-02-2023, 04:13 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
