Updating a BIOS on ASROCK
  • paulwal
    • Apr 2023
    • 6
    Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
    https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
    I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
    CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
    Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
    It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
    1. BIOS 3.40, then
    2. AMD all in 1 with VGA driver ver:18.50.16.01_WHQL, then
    3. BIOS 5.40, then
    4. BIOS 5.80
    Any help will be appreciated. Thanks. Paul
  • Kougar
    • Nov 2022
    • 5
    Re: Updating a BIOS on ASROCK
    That is seriously the most convoluted BIOS flashing process I have ever seen. It's almost easier to install a newer AM4 processor just so you can skip most of those steps.
    Yes, your chip is Summit Ridge. Your order of installations looks correct.
    • paulwal
      • Apr 2023
      • 6
      Hey, thanks so much for the reply. Hope your day is a good one.
      • Luigi123
        Need full SPI BIOS dump – ASRock Z590-C/ac (CH341A recovery)
        by Luigi123
        I’m looking for a full raw 16 MB (128 Mbit) SPI BIOS dump for an ASRock Z590-C/ac motherboard.
        Issue / symptoms:
        The board powers on (fans spin, USB devices get power), but there is no POST, no display output, and no beep codes, even with a speaker connected and RAM fully removed.
        What happened:
        I attempted recovery using a CH341A external SPI programmer after a failed BIOS update. I flashed the official ASRock BIOS v1.30 file directly to the chip. I later learned this file is intended for Instant Flash only and is not a complete...
        01-16-2026, 12:49 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • gabrieljma1
        Request: Full BIOS dump for ASRock Z790-CX (DDR5)
        by gabrieljma1
        I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
        The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
        I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
        10-08-2025, 03:32 PM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
