Asus V241EP Bios
  • CG2
    • Nov 2022
    • 37
    Asus V241EP Bios
    I've got an Asus V241 All in one PC with a blank screen. Shows nothing at all. I've been through all the obvious but nothing helps, so I'm looking to flash the BIOS.
    There are two flashable chips on the motherboard, a 24C16WP eeprom with a whole 2k bytes, and a 4Mbit 25L4006E cmos serial flash chip, so I'm assuming the latter. I've pulled it and read it, but I can't see anything and neither can UEFITool, so it's either corrupt or encrypted.
    I can download the BIOS from Asus, but the image size is almost 20MB, and I've only got 500K of chip space to squeeze it onto. I guess that I only wnat part of it, but I've no idea which part. Does anyone have any hints where to start?
  • hardware1
    • Sep 2021
    • 2951
    • N/A
    Re: Asus V241EP Bios
    You must have a bigger storage chip like (64 Megabit or 128 Megabit).
    when you find it read it and upload the original file and someone will help you.
    Also you should write your device serial number.
    all donations are welcome,
    • CG2
      • Nov 2022
      • 37
      D'oh. That's embarassing. There's a Winbond 25Q128JVPQ 128M-bit sitting right beside the battery on the other side of the board. Thanks for the help and apologies for being so dumb.
      • hardware1
        • Sep 2021
        • 2951
        • N/A
        No Problem friend. if you can't do it by yourself, just upload the file and write your serial number.
        • nedd119
          • Oct 2020
          Hi, i have the same issue with an Asus V241 all in one, power led flashes slowly twice, tried flashing new bios but same issue, no output to screen, 19v, 5v and 3.3 present...any help on this issue would be appreciated
          • peste
            • 14052
            • ROMANIA
            did you check on an external monitor... did you change the ram memory..
            • nedd119
              • Oct 2020
              Yes tried with working ram and output from hdmi but no post, the power led flashes twice as soon as the power connector is attached.
              • peste
                • 14052
                • ROMANIA
                post the original bios even if it is corrupted
                • nedd119
                  • Oct 2020
                  Hi, it was was the soldered on CPU, reflowed and it working temporarily, new mobo required, thanks anyway
                  • kk126
                    • Mar 2021
                    • 18
                    • mexico
                    This is my bios, no video and power led blinking, i attach it w/ serialnumber
                    M8PTCJ007871312
                    hope you can help me
                    • hardware1
                      • Sep 2021
                      • 2951
                      • N/A
                      M8PTCJ007871312
                      Here's your New BIOS, try it and let me know.
                      • hollo13
                        • Mar 2017
                        • 21
                        • Hungary
                        This is my bios, no video and power led blinking, fan spinning.
                        SN:N8PTCJ01B42335H.
                        • danito
                          • Jun 2016
                          • 1308
                          SN:N8PTCJ01B42335H.
                          try
                          • hollo13
                            • Mar 2017
                            • 21
                            • Hungary
                            Thank You , danito! Working!
                            • yinlaino
                              menoscero
                              • Oct 2014
                              • 34
                              • Colombia
                              Hi friend, can you help me with this BIOS? It turns on but doesn't show video, please?
                              Asus
                              V241EP R2.2
                              S/N N8PTCJ01C34035G
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12532
                                Asus
                                V241EP R2.2
                                S/N N8PTCJ01C34035G
                                V241EA
                                • yinlaino
                                  menoscero
                                  • Oct 2014
                                  • 34
                                  • Colombia
                                  Originally posted by hoaca388
                                  V241EA
                                  Friend, it doesn't work for me, it turns on and off with the original, it turns on without video
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12532
                                    Post QR code in mainboad.
                                    • Nekozawa
                                      • Mar 2020
                                      • Kazakhstan
                                      V241EP R2.1
                                      s/n N7PTCJ00K36728B
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12532
                                        V241EP R2.1
                                        s/n N7PTCJ00K36728B
                                        V241EA
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
