Asus P8Z77 V bios
  • sergioservice
    • Oct 2020
    • 6
    • Spain
    Asus P8Z77 V bios
    hello. have anyone Dump bios for this board? i have rev. 1.02
  • hoaca388
    Badcaps
    • Jan 2022
    • 11649
    Re: Asus P8Z77 V
    https://www.asus.com/supportonly/p8z77v/helpdesk_bios/
      • 20695
      Re: Asus P8Z77 V
      Download the bios from asus support https://www.asus.com/supportonly/p8z...esk_knowledge/
      Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body" .That will remove the 2KB CAP header.Save the file as *.rom or *.bin
      UEFITool - https://github.com/LongSoft/UEFITool..._A57_win32.zip
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
