Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Need asus prime z490-p bios dump
  • ossdr
    • May 2015
    • 18
    • amman
    Need asus prime z490-p bios dump please
    motherboard no data WITH RAM BEEPS
    OR CLEAR ME OLD BIOS
    • 23095
    Re: Need asus prime z490-p bios dump
    Make a backup first,then download any bios version from asus support https://www.asus.com/Motherboards-Co...HelpDesk_BIOS/
    Extract from the zip folder.Open the "PRIME-Z490-P-ASUS-****.CAP" bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body" .That will remove the 4KB CAP header.Save the file as *.rom or *.bin
    UEFITool - https://github.com/LongSoft/UEFITool..._A57_win32.zip
    If you want to clean the ME region we have some guides: How to clean ME/TXE region - https://www.badcaps.net/forum/showpo...41&postcount=3
    • Kurgan77
      • May 2024
      • 13
      You are awesome....I didn't realize I had flashed 2 ASUS MOTHERBOARDS BEFORE I STARTED TO THINK WHAT IS GOING ON…I WAS DOUBTING MY REPAIRS, LOL, then on the third board I was like wait a minute.
      • ronaldopdias
        ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
        by ronaldopdias
        I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
        • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
        • BIOS file downloaded directly from the official ASUS support page.
        • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
        Issue:
        The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
        Because FlashBack didn’t work, I:
        • Removed the BIOS SPI IC from
        02-04-2026, 03:16 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
