Asus bios, PRIME A520M-K bios
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    can someone help me extract this bios from this cpmpressed file i got from the official website, Asus bios, PRIME A520M-K bios
    i have the downloaded file below
  • peste
    • 13550
    • ROMANIA
    Re: Asus bios, PRIME A520M-K bios
    Originally posted by mnciks11
    Hello guys
    also post the original bios
      • 21841
      Hello guys
      Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body"
      UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        Here it is Peste
        • peste
          • 13550
          • ROMANIA
          Here it is Peste
          try post #3...
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            Try
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
