bios bin file wanted thanks inadvance
ASUS P7P55D rev:1.02g bios
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lrouw84Hi there,
I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
by DynaxSCHi,
Usually on ASUS boards it worked...-
- Loading...
