hello every one please i need the bios without password for this motherboard
lenovo m715q am4ih ver : 1.0
Tags: None
Re: lenovo m715q am4ih ver : 1.0
No, no, you know the forum rules.↵
https://www.badcaps.net/donate -
my backupAttached Filesif you find these attachements useful please consider making a small donation to the site
M715q Desktop (ThinkCentre) - Type 10M2
Try code first : wFF8}3UD{U5f]Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hello friends can someone help me please.. I have thinckcentre M715Q 2TH GEN AMD with corrupted bios, can you rebuild amd? I found a file on the web that turns on but the dmi information is missing, I have tried to write serial but I have not succeeded, I tried to do it with amidedos, but an error appears (image attached) I also tried it with Thinkpad maintenance diskette, and with this an error appears write protected bios error...
Could someone please help.Hello friends can someone help me please.. I have thinckcentre M715Q 2TH GEN AMD with corrupted bios, can you rebuild amd? I found a file on the web that turns on but the dmi information is missing, I have tried to write serial but I have not succeeded, I tried to do it with amidedos, but an error appears (image attached) I also tried it with Thinkpad maintenance diskette, and with this an error appears write protected bios error...
Here's you New Bios, it's a Virgin Bios from Lenovo with your DMI and Windows Key.Hello friends can someone help me please.. I have thinckcentre M715Q 2TH GEN AMD with corrupted bios, can you rebuild amd? I found a file on the web that turns on but the dmi information is missing, I have tried to write serial but I have not succeeded, I tried to do it with amidedos, but an error appears (image attached) I also tried it with Thinkpad maintenance diskette, and with this an error appears write protected bios error...
Serial Number: MJ080Y02.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Use new version of LMU
https://www.badcaps.net/forum/showpo...4&postcount=28----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thanks Bro, the dmi were perfect, but I have the fan at full speed, the same thing happened to me before with the bios that I had before without dmi data... or will this model be like that?Comment
Thanks bro, I sent you a PM.Comment
You're Welcome. It's an AMD Platform and there's no ME Region, so it's supposed to be a normal thing. Also it could be fan failure or a hardware issue I don't know.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Solved Bro, I leave the information for someone who is going through this problem, I solved it by downloading an ec update from the lenovo sd website attached image of the driver that solves fan at full speed again thanks for your help.
Thanks, bro you saved my life !Comment
Thanks, broComment
LENOVO M175q
NO DISPLAY PLEASE HELP WITH NEW BIOS
BACKUP AND SERIAL NUMBER : MJ065MRNAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I also have the black screen / fan high / no boot issue after a failed BIOS update.
I've dumped both the EC and BIOS (see attached file) and also tried to update the thinkcentres externally (via USB).
Also tried flashing the BIOS chip directly, sadly without any change.
I'd be happy if someone could verify these dumps and tell me how I may proceed because I suspect that the EC firmware update failed as flashing the BIOS chip doesn't help and I can't find any information about flashing the EC.
Model: M715q - 10M2
Serial: PC0NHQUJ
Thank you very much in advance
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by claws77my laptop is lenovo flex 5 14ITL05
recently my power supply for this laptop developed a fault.
which caused a short in my usb c port -- verified with a new charger.
rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32... -
by darknwoHi, can someone help me please with the removal of the bios password of this dump.
Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...-
by pevata9811Hello, I have one Lenovo T14 Gen 2 with a BIOS password and another identical one without a password. I have BIOS and EC programmers. Is there a way to unlock the password, or maybe I can read the EC from the unlocked one and flash it to the locked laptop? I also have two T14s Gen 2 units with BIOS passwords. Any help would be greatly appreciated.
- Loading...
