Need BIOS DELL 3046 SFF
  • szdnkx
    • May 2022
    • 10
    • China
    service code:25916802086
    need the bios write by the flash tools.
    Thanks.
  • peste
    • 13561
    • ROMANIA
    Re: Need BIOS DELL 3046 SFF
    Thanks.
    post the original bios ..
    • szdnkx
      • May 2022
      • 10
      • China
      The customer brushed the BIOS and it broke.
      I mean do you have the factory bios?
      • peste
        • 13561
        • ROMANIA
        post it so broken, maybe we can fix it
        • tahirkhan1983
          • Feb 2012
          • 16
          My Dell Optiplex 3046 currpeted bios
          please build for me the ok bios. thanks.
          the reg model of my pc is D11S
            • 21841
            Post the service tag.
            • tahirkhan1983
              • Feb 2012
              • 16
              the board number is NP-140TL KCN0P
              service tag is 4p867j2
              • Maxi.K
                • Aug 2021
                • 5
                • Buenos Aires
                try this please
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • gizaha
                  by gizaha
                  02-13-2024, 07:18 AM
                • mrrubik
                  Dell Optiplex 7010 micro bad BIOS flash?
                  by mrrubik
                  Hi folks,
                  I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                  After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                  Steps I took:
                  1. Read BIOS with CH341a, verified hash twice
                  2. Patched
                  12-23-2024, 04:11 PM
