Intel NUC8i5INH BIOS Request / Repair
  • REpairAT
    • Nov 2020
    • 142
    • Austria
    need BIOS for NUC8INB please. Attached, my Backup and newest CAP file from Intel Homepage (if needed)
    Thanks in advance!
    BR, Ray
    Last edited by SMDFlea; 05-11-2022, 04:58 AM. Reason: Added model number NUC8i5INH
    • 20848
    Re: Intel NUC8INB BIOS Request / Repair
    Thanks in advance!
    BR, Ray
    Intel CAP files can`t be extracted.Did you try cleaning the ME firmware,its the first thing you can try.If cleaning it doesn`t work then you will need a bios dump. What is the full model number, is it one of these NUC8i3INH ,NUC8i5INH ,NUC8i7INH
    • REpairAT
      • Nov 2020
      • 142
      • Austria
      NUC8i5INH is mine. Is there any tutorial to learn how to clean the ME? I'd do it all by myself instead of bugging people here, if I would know how
        • 20848
        Yes there`s some guides.In the first one you`ll find all the links to the ME tools ,firmware repositories and win-raid forums ME Cleaning guide.
        https://www.badcaps.net/forum/showpo...41&postcount=3 .Follow the win-raid guide: "D4. CSME 11 - 15 & CSTXE 3 - 4"
        Attached is Flash Image Tool (FIT) 12 ,and firmware version "12.0.64.1551_CON_LP_C_PRD_RGN.bin" renamed to "ME Sub Partition.bin" .
        MEAnalyzer https://github.com/platomav/MEAnalyz...274.0_r277.rar
        • REpairAT
          • Nov 2020
          • 142
          • Austria
          Re: Intel NUC8i5INH BIOS Request / Repair
          Thanks a lot, that was really helpful!
          I managed to clean ME region regarding to your manual, sadly the problem persists. I'll check for other faults as soon as I find some time, but knowing how to fix ME related issues probably helps me with other devices in future.
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • nosfay
            Intel NUC NUC10i5FNK - Bios & firmware request
            by nosfay
            I need clean bios & firmware for an intel that doesn't boot.
            Model : NUC10FNK
            Product code : BXNUC10i5FNKN2
            Here is my dump, but i dont know which one is the bios or firmware as there is 2 different chip, MX25L25673G and MX25V8035F so I've dumped both.
            Thanks for your help !
            EDIT: you can find official bios and firmware here https://www.asus.com/supportonly/nuc...helpdesk_bios/...
            11-01-2024, 08:10 AM
