Imac 2017 a1418 emc 3069 820-00597-a schematic and boardview
  • Snazzysmith
    • Aug 2017
    • 8
    Here they are in case anybody else wants them.
    Included is:
    schematic
    Boardview
  • rockinho
    • Mar 2014
    • 12
    • Argentina
    Re: Imac 2017 a1418 emc 3069 820-00597-a schematic and boardview
    Thanks bro!!!
    • nhattamlaptop
      • Mar 2017
      • 21
      • Viet Nam
      thanks very bro
      • MicroSMD Lab
        • Sep 2018
        • 137
        • Trinidad and Tobago
        Much appreciated!
        • brithetechguy
          • May 2021
          Question for you guys what program are you using to view the .brd files in? I tried using Open Boardview and it's not working I also tried Cadence Allegro and it also wouldn't read the file.
          • Stefanosky71
            • Jun 2023
            • 3
            • Italy
            Thanks a lot
            • advancedtechs
              • Aug 2023
              • 9
              • FL
              thanks
              • Neodim
                • Jul 2020
                • 3
                • Ukraina
                Thanks a lot
                • pepegotera454
                  • Jul 2014
                  • 15
                  • andorra
                  Thank you so much.
                  • agittan@yahoo.com
                    • Aug 2018
                    • India
                    Thanks alot for sharing
                    • Agamahaga
                      • Aug 2020
                      • 8
                      • Indonesia
                      Thanks...
                      • guzq
                        • May 2017
                        • 53
                        • Indonesia
                        Thanks Man for sharing 🍻
                        • pwheels
                          • May 2025
                          • netherlands
                          THANKS for SHARING
                          • ryankou
                            by ryankou
                            IMAC 2017 A1418 EMC 3069 820-00597-A
                            Any one know about MDM Lock?
                            Will it remove the MDM lock after change the SN?
                            Do I need to re install the os after change SN?
                            Here is my back up bin with MDM locked
                            Thanks...
                            02-08-2021, 11:27 AM
                          • boheman
                            Apple iMac 820-01061 A EMC 3069 2017 21.5
                            by boheman
                            Hi!
                            I'm looking for any experience about 2017 iMac with random shut down.
                            It's a working one but only I can use for 4-5 minutes, after shut down and cannot turn it again. But I tried it a few days later (5-6 days) and it works, and after 4-5 minutes crashed again.
                            All of the voltages fine on the board, and no visible damage or burned components or water damage. No shorts to the ground.
                            I replaced a couple components to find the problem: PSU, CPU, RAM, RTC battery, BIOS.
                            Only I find LCD backlight fuse dead caused by bad LCD cable, I replaced it...
                            01-29-2023, 08:18 AM
                          • ryogadan78
                            iMac A1418 - No LED, no power after overvoltage on Ethernet port
                            by ryogadan78
                            Hi guys, I need your help again.
                            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                            06-10-2025, 03:49 AM
                          • tommy97
                            iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                            by tommy97
                            we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                            Any ideas what might've...
                            04-20-2024, 04:48 AM
                          • roman728
                            iMAC A1418 Backlight issue
                            by roman728
                            Hello friends,
                            I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
                            Can you...
                            04-10-2025, 11:48 AM
