dell xps 18 1810 bios aio
  • emaghanim
    • 133
    • egypt
    for backup only
    work 100%
    dell xps 18 1810 VER A10 aio bios
    board IMPCR-CS REV 1.03
  • kayitsiz
    • May 2017
    • 18
    • istanbul
    Re: dell xps 18 1810 bios aio
    thanks it work
    • ofyesilyurt
      • Jul 2016
      • of..
      Hello there
      I'm new to you, I need the software of the device (EC) in this topic, can you help me?
      • drnbilisim
        • May 2023
        • 6
        • turkiye
        Originally posted by emaghanim
        for backup only
        work 100%
        Hello there
        I'm new to you my dell xps 18 didn't work in 1810 it was interrupted while updating the bios from the system I need a dump file with full cleaning
          • 21841
          Originally posted by drnbilisim
          Hello there
          Post your service tag and bios backup,even if its corrupt.
          • drnbilisim
            • May 2023
            • 6
            • turkiye
            Service tag 4GRVTX1
            I do not have a working bios backup available, I would appreciate it if you could help me
              • 21841
              Service tag 4GRVTX1
              Do you have an SPI bios programmer ? ,can`t you make a backup and post it .
              • drnbilisim
                • May 2023
                • 6
                • turkiye
                There is no software left that I can backup, they have done amateur work on it.
                i need a copy
                • drnbilisim
                  • May 2023
                  • 6
                  • turkiye
                  • volinakis
                    • Jan 2021
                    • 2873
                    • N/A
                    you can extract it from bios update, since you didn't post any info about your laptop, as in RULES, we can't help you but a photo.
                    • TACHGO
                      • May 2023
                      • United Kingdom
                      thank you this worked 😋
                      • webhost
                        • Aug 2019
                        • 86
                        • Belgium
                        hello
                        can somone fix this bios my dell start 4 second and turn off
                        thank you
                        dell AIO XPS 18
                        motherboard : HannStar J 94V-0 MV-4
                        serial : GFYBTX1
                        • danito
                          • Jun 2016
                          • 1091
                          • Romania
                          Originally posted by webhost
                          hello
                          thank you
                          dell AIO XPS 18
                          serial : GFYBTX1
                          try
                          • drnbilisim
                            • May 2023
                            • 6
                            • turkiye
                            MOTHERBOARD IMPCR-CS REV:1.03 service tag:4GRVTX1 I DO NOT HAVE ACCESS TO THE BIOS FILE
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • capoplays
                              Help with BIOS update on Dell G15 5515 after chip replacement
                              by capoplays
                              Hey everyone,
                              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                              When I check the BIOS using the F12 menu Flash...
                              Yesterday, 06:53 AM
                            • mrrubik
                              Dell Optiplex 7010 micro bad BIOS flash?
                              by mrrubik
                              Hi folks,
                              I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                              After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                              Steps I took:
                              1. Read BIOS with CH341a, verified hash twice
                              2. Patched
                              12-23-2024, 04:11 PM
                            • bmxlovah
                              Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                              by bmxlovah
                              My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                              11-24-2022, 06:29 AM
