asus desktop m4a87td/usb3 bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    my friend
    i need desktop asus motherboard bios dump. I tested all of the Asus support bios and I can't get pictures
    note: your bios has this error
    thanks
    • 21109
    Re: asus desktop m4a87td/usb3 bios dump
    bios
    • asliyucegsm
      • Jun 2011
      • 347
      • Turkiye
      my friend was returned to the customer
      thanks
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
