Asus Prime Z270-P Dump Bios Request
  • aysat
    • Feb 2015
    • 17
    • Kazakhstan
    Hi guys,
    i have purchased a broken mobo mentioned above and i need the dump bios. if anyone can provide , please do so. it will be highly appreciated.
    Unfortunately, bios was replaced before me and cannot dump an empty chip
    Have a good day,
    Alper
    • 21164
    Re: Asus Prime Z270-P Dump Bios Request
    Originally posted by aysat
    Hi guys,
    Have a good day,
    Alper
    Download the bios from the support site,extract from the zip file,open bios_name.CAP with UEFITool, select: Action - Capsule - Extract Body
    https://www.asus.com/Motherboards-Co...HelpDesk_BIOS/
    https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • aysat
      • Feb 2015
      • 17
      • Kazakhstan
      hi,
      thank you for your input. will this work instead of a dump bios ?
        • 21164
        hi,
        Yes.Its a virgin bios with clean ME firmware.If the latest one doesn`t work try an older one.If that doesn`t work then your problem is somewhere else
        • aysat
          • Feb 2015
          • 17
          • Kazakhstan
          you are right. flashed it with ezp2019 programmer and it works again. it allows me to choose .cap and flashed without extracting body. such a nice feature
          • OKRPKCOMP
            • Dec 2020
            • 432
            • PAKISTAN
            • xxcxx
              • Feb 2013
              • 31
              • portuguese
              I need a dump to mainboard - AsusPrime Z370-PII and boardview , where i can find it please ?
                • 21164
                Not in this thread, its for the Z270-P bios. If you can`t find a Z370-PII bios request topic or a Z370-PII boardview request topic using the forum search engine then start your own threads. Post each thread seperately.
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • reset1986
                  Asus prime b550m-a bios dump
                  by reset1986
                  Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                  06-22-2025, 04:17 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
