Asus Prime Z270-P Dump Bios Request
  • aysat
    • Feb 2015
    • 17
    • Kazakhstan
    Hi guys,
    i have purchased a broken mobo mentioned above and i need the dump bios. if anyone can provide , please do so. it will be highly appreciated.
    Unfortunately, bios was replaced before me and cannot dump an empty chip
    Have a good day,
    Alper
    • 22112
    Re: Asus Prime Z270-P Dump Bios Request
    Originally posted by aysat
    Hi guys,
    Have a good day,
    Alper
    Download the bios from the support site,extract from the zip file,open bios_name.CAP with UEFITool, select: Action - Capsule - Extract Body
    https://www.asus.com/Motherboards-Co...HelpDesk_BIOS/
    https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • aysat
      • Feb 2015
      • 17
      • Kazakhstan
      hi,
      thank you for your input. will this work instead of a dump bios ?
        • 22112
        hi,
        Yes.Its a virgin bios with clean ME firmware.If the latest one doesn`t work try an older one.If that doesn`t work then your problem is somewhere else
        • aysat
          • Feb 2015
          • 17
          • Kazakhstan
          you are right. flashed it with ezp2019 programmer and it works again. it allows me to choose .cap and flashed without extracting body. such a nice feature
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            • xxcxx
              • Feb 2013
              • 31
              • portuguese
              I need a dump to mainboard - AsusPrime Z370-PII and boardview , where i can find it please ?
                • 22112
                Not in this thread, its for the Z270-P bios. If you can`t find a Z370-PII bios request topic or a Z370-PII boardview request topic using the forum search engine then start your own threads. Post each thread seperately.
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • ASB
                  Asus Prime B450-Plus Bios Modification (USB Overcurrent)
                  by ASB
                  I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
                  11-12-2025, 06:17 AM
