Need H61m-s2p rev 2.1 schematic
  • bembeno
    • Feb 2016
    • 311
    • egypt
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Re: Need H61m-s2p rev 2.1 schematic
    How do I post an attachement?
    • Ritchie_Uk
      Prawnography
      • Mar 2021
      • 185
      • Uk
      Enjoy
      • 3ali3ali
        • Feb 2022
        • africa
        Originally posted by Ritchie_Uk
        Enjoy
        thank you sir
        • kadi144
          • Aug 2015
          • 690
          • algerie
          thankS
          • GOKUU
            • Oct 2022
            • India
            Enjoy
            GA-H61M-S2P an GA-H61M-S2PV-WG, are they both same
            • AL._.EX
              • Dec 2022
              • 896
              • Belarus
              Schematic & boardview
              • MATRIX COMPUTERS
                • Dec 2018
                • 11
                • tanta
                Enjoy
                thank you
                • nassimhamdi
                  • Feb 2016
                  • 150
                  • algeria
                  thank you so much
                  • chaos-theory
                    RX580 MSI armor OC 8gb no post
                    by chaos-theory
                    I have a card that does post at all, the owner said it does go into windows but it gets stuck on the logo with artifacts, I have no idea if he is lying or not... I tried the card on my pc and it does not post at, no beeps, no bios nothing just all fans turning and nothing else. I tried plugging DVI or hdmi but nothing, I tried unplugging the 8 pin plug from the power supply and it's the same thing.
                    I just want it to post and get into the bios at least.
                    Forgive me if I am wrong, but I tested the 3 PCIe 12v power pins on the left(550ohm) and the 4th one from the right 3.3v (400ohm),...
                    04-18-2024, 02:42 AM
                  • atunguyd
                    Acer x163w Monitor PSU schematic
                    by atunguyd
                    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                    03-05-2025, 02:08 PM
                  • Sorrow1
                    Intergraph TDZ 2000 mainboard post code 2F/2E
                    by Sorrow1
                    I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                    It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                    When I recorded video of POST card and played it in slow...
                    01-03-2024, 04:13 AM
                  • Twiesel
                    Asus ROG Strix B450-F Gaming II stuck on POST
                    by Twiesel
                    Hey y'all,
                    I am currently working on an Asus ROG B450-F Gaming II ATX Mainboard. The board is in very good condition (no missing components/scratches), but when I power it on using a Ryzen 3 1200 and one stick of DDR4, it gets stuck at 1,4A with none of the POST-LEDs lighting up.
                    I checked all voltages, which are present. The CPU gets slightly warm.
                    What I did try:
                    -Resetting CMOS
                    -Reflashing BIOS (manually and using the flashback tool)
                    -"cleaning" the socket with isopropyl alcohol
                    -using several sticks of DDR4 in every slot...
                    12-01-2024, 04:14 PM
                  • bbenalmadena
                    UX461UA no post, fix
                    by bbenalmadena
                    Hi, been banging my head two days with a UX461UA Zenbook Asus that will not post. Laptop looks ok, all voltages looks nominal, CPU gets hot, even fan kicks in when it gets hot, I removed the m2 drive and tried several things, I thought it was a bios issue, I even registered here to try flashing with some BIOSes but the problem still was the same, no POST
                    At last I decided to check the disk drive to see if any backup can be done and then I realized that the disk drive was broken, I thought what are the odds that the motherboard and the drive at the same time? So I just plug another...
                    09-05-2024, 02:18 AM
